I ordered a replacement clutch assembly but can't figure aout hou to remove the old one. Can anyone help?
Remove the little rubber feed on the bottom of the base (they might be glued a bit so be careful not to rip them). This will reveal 4 phillips head screws...remove them...this will open the base and reveal the back site of the rotor. In the middle you will see a turban blade like wheel with a large flat tip screw. Wedge a large screwdriver between the teeth of the old clutch so that when you turn the flat tip screw it will stop rotating the other end. Turn the screw with some force to the right to losen the clutch...then do the reverse to get the new one on tight...put everything back together and there you have it.
Keep in mind that this might void your warrenty if you still have some on it.
Hi, plz try this link if it works:
http://www.beveragefactory.com/refrigeration/blenders-juicers/blenders/MBB518.shtml
Hello
There are two type of fittings for this gear. In some models it will be push in type, and for others it will be screw type. If your model has push type one, just pull out it from the shaft. You may have to excert a strong force to pull it out. If it is screw type, you have to open its lower lid by unscrewing its secrews, hold the cooling fan and hold the gear at the top, twist it in 'CLOCKWAYS' direction, [not counterclockwise], to screw it out. OK.
Answered by Gopakumar Gopalan 228 days ago
I have the same problem. My blender is from Hamilton Beach. Though I tried to unscrew the crutch, I could not do it because the motor part is also moving. Please let me know when you find how to replace it.
Thank you.
