Question about Brother HL-2040 Laser Printer
Printer drum light on
Drum light is on it still prints but have light ink smudge marks on paper
  • 22 Answers
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Posted on Mar 31, 2007
  • glrymaher Dec 15, 2010
    Thanks so much for such easy to follow advice.
Thanks for your advice - I can't believe I wasn't able to find this advice on the Brother website!!
Posted on Oct 24, 2007
I have the same problem at the moment i have been holding down the go button to reset the printer it seems to work for a dozen or so prints , However Iam after a more permanent solution my self
Posted on Aug 27, 2007
Totally worked you guys are amazing
Posted on May 02, 2007
Experiencing ink smudge on regular bond paper and pre-printed checks.
check the photoconductor or drum unit for printer. i think the drum unit could be damaged thats why the marks are appearing on the page.
Jan 07, 2011 | Brother HL 5250DN Laser Printer
My printer streaks ink across the paper when i print
just replace toner cartridge. I think the cartridge drum is broken
May 21, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Printing has smudge on edge
If it is right along the edge then the drum (well the cleaning blade of the drum) is faulty. In a unit like that I suspect it is all part of a toner cartridge. Try replacing that and I think you will be good.
Jan 01, 2010 | Epson AcuLaser C900 Printer
Smudges on paper and ink is light when it does copy correctly.
It sounds like your drum unit needs to be replaced. Do the smudges look characteristically like a finger print? Technicians have a rule of thumb. Replace your drum, developer compound and general service the machine as often as you service your car. Assuming you do service your car as often as I do, it should be after every 25,000 copies. If the machine has never been serviced then its time you did.
May 25, 2009 | Sharp AR-5320 Black and White Copier
HP LaserJet 1100A unwanted toner marks on face of print
check this link,
either fuser or print drum. to verify , start print job, open door before finnished and see if marks appear before or after fuser. Before paper gets to fuser toner ink will smudge.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl70340#RepImgDef
Feb 15, 2009 | HP LaserJet 1100a Printer
Blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Sep 02, 2008 | HP Color LaserJet 2600n Printer
Printing Black Smudges
You could print a few more out and see if it goes away.
Check the drum and see if there are any black marks on it. If there is, it could be a scratched drum or the cleaning blade isn't working in it anymore.
Is this a new toner cartridge?
Be careful when you look at the drum at it to keep the light out of it as much as possible.
Where did it jam at?
Jun 13, 2008 | Samsung CLX-3160 All-In-One Laser Printer
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brothers 5-1 lasar multicenter
What model - Epson under heading. Brother as you speak, you speak of ink but also of a drum, machines that use a drum dont use ink. they use toner, so I guess you have a Brother MFC ???? ie 8820. Did you buy gen Brother Drum and Toner?
Is the insides of printer clean or full of powder?
Is there any image?
Stop a print halfway in machine and see if mark only occurs after paper has traveled threw the fuser (the hot bit at rear)
Oct 28, 2007 | Epson Stylus Photo 1280 InkJet Printer
Brother HL-2040 Laser Printer Logo
6,989 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
