Question about HP Photosmart 3210 Printer
HP Photosmart 3210 : scanner failure, unable to scan or copy
HP Photosmart 3210 gave an error message appears atop a yellow triange with an explanation point in the center. The only message when I went to make a copy was: scanner failure unable to scan or copy.
  • 2 more comments
  • bupp6 Dec 21, 2008
    problem solved. turned it off and on several times and it reset it self.:)
  • Juniperland Jan 17, 2009
    My HP C7230 all in one machine can fax out when I work from the machine. It tests correctly using the HP Solution Center on my Vista system. But when I fax using that application, it quickly responds FAX FAILED.
  • piratemonk Feb 14, 2009
    Same exact issue. I think it has something to do with it running on a wireless network - but not sure.
  • Anonymous May 18, 2009
    i have the smae problem but on a HP Photosmart 2575 all in one
khanmohammad
  • 188 Answers
SOURCE: Ink system failure
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=us&lc=en&dlc=en&product=439488
Else please chat with HP online technical support.
The chat support is free of cost, where you can chat with HP online technician.
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=aio&productName=HP+Photosmart+3210+All-in-One&productCategory=421635&SCOID=238445&PSOID=439599&aoid=null&lang=en&cc=us
Have a great day!
Posted on Mar 27, 2008
Roop1980
  • 228 Answers
SOURCE: Ink System Failure (Error 0xc05d1381)
To resolve the issue, use the following steps.
Step one: Remove the cartridges
Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
Open the product cover and remove the cartridges.
Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
Open the product cover and reinstall the cartridges.
Close the cover and print a calibration page, if prompted.
Print a self test report to make sure that the product can print.
Reconnect the USB cable between the product and the computer.
Try to print a document from an application on the computer.
If the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
Posted on Apr 11, 2009
SOURCE: ink system failure
I, too, used the same solution of holding down "OK" "CXL" and "BLACK COLOR" at the same time. Printer will restart itself and everything is a-ok!
Posted on May 04, 2009
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
pineworks
  • 4041 Answers
SOURCE: I have a HP Photosmart 3210 and it says Error
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Printer HP Photosmart 3210 will not work
I put item to be copied on the copier glass. I press copy. On copy menu I press number of copies. I press OK I press color start button. The copier starts to work and then a message apprears on the copy screen ' UNABLE TO SCAN " and the command is aborted. I have tried checking drivers and they are okay.
Apr 13, 2011 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
When attempting to scan document or copy a document on Photosmart all in one seriers I receive an error message "Scanner failure unable to scan or copy"
try to remove and re install driver, and look into device manager if scanner detected. if not restart you pc and when found new hardware popup browse driver manually.
Apr 10, 2010 | HP Photosmart 3310 Printer
Message says "Scanner Failure" and "Unable to scan or copy"
Obviously its scanner error,the whole scanner assembly needs replacement.It could be the bulb or the scanner board, but upon replacing it needs both.
Sep 17, 2009 | HP Photosmart C5280 InkJet Printer
I have a HP photosmart 3210 All in one. It is showing an error message; ink system failure. Ink system has failed unable to copy, receive faxes, or print. Refer to printer documentation. Error 0xc18a0401
Hi ok try this I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Dec 21, 2008 | HP Photosmart 3210 Printer
HP PHOTOSMART 7180 ALL IN ONE
how to reduce the baud rate in all in one printer
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP 3210 failure code
Hi Pddunstan,
Have a great day!
Mar 09, 2008 | HP Photosmart 3210 All-In-One InkJet...
I have a Ink System Failure.
I had this same problem but with a different error code. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Mar 02, 2008 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
1,766 people viewed this question
Seeker5211
Seeker5211
