Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
My washing machine started to give problem this week, it runs for about two minutes then stops. I start it again then stops again.
Whats the best place to start to troubleshoot this problem?
Thanks in adance.
  • 2 more comments
  • atif03 Dec 20, 2008
    I tried this for both intake and outtake, intake water comes just fine.
    When machine is filled with water, when its suppose to turn to next cycle where it drains the water and start spin it does not do that. I try to set it manually it does not drain water nor spin. I'm guessing its either timer problem or water drain pump possible motor?
    when i took the outlet hose out the water that was in the machine started to come out. Also outlet hose was not clogged either.
    can any one offer any other suggestions?
    thanks
  • atif03 Dec 25, 2008
    well i changed the timer, only problem now is that it stops when its time to drain the water, the water isn't draining. I need to check water pump but i'm unable to open the bottom part, can any one provide instructions or server manual. Thanks
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold ...my screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Posted on Dec 19, 2008
FH error code frustration
Replace main control board and pressure switch together .
May 26, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
My duet washing machine throughs out a FH code
FH is a water inlet related issue, make sure your cold water supply is working correctly, sounds as if its trying to rinse(cold water) and has no water to do it
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machine GE Profile/prodigy
you have a dry on your programmer you should not do this your self i would go down and see your local second hand shop who can help you with is they normally do jobs like that appliance shop is the best place to go it will be cheap
Dec 03, 2007 | GE Profile Prodigy WPSE4200A
Samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Oct 13, 2007 | Washing Machines
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
