Question about Panasonic DVD-LA95 Portable DVD Player
Portable DVD player won't read discs.
When I attempted to watch a DVD recently on my Portable Panasonic DVDLA95 DVD player, all it did was spin the disc, click a lot, and present the word reading. I shut it down and it read ERROR H03, shut off then left visible LCD lines at the top of the screen. I read online that about the only thing you can do for that code is to take all power supply away for 30 minutes and reset all the memory codes. Where I was reading this, however, was a question and answer site, and the questioner said his discs were not spinning and his player would lock up. Fortunatly, Mine has none of those symptoms. I have disconnected the power sources and I am still waiting for results, but can you tell me if there are any further actions I could take should the 30 minute power starve not work?
  • mech747400 Feb 13, 2009
    won't read the disc or spin
I had the same problem with my Panasonic la95's. I read a couple of posts talking about a similar problem with other Panasonics and the failures seemed to focus on the threaded spindle that the laser assembly rides on as it scans the DVD. I took off the back of the player, opened the case and cleaned and lubricated the spindle with some wd40. I put the wd40 on a q-tip so as to not spread it too far). I also turned the spindle a few revolutions to move the laser back away from the center (in case it was stuck too far in). Voila. When I put it back together it read the DVD and it worked. Big thank you to the others who have posted solutions.
Posted on Jun 13, 2009
  • 3 Answers
There are 2 errors, ho3 and ho2, I can't remember which one is which. One means the laser is going and one means it's a dirty track. I suggest you first very gently clean the lens. If that doesn't work you take apart the player and clean the whole track that the laser moves on along with everything around it (keeping in mind that the laser is fragile). If that doesn't work than I can't help anymore without seeing it.
Posted on Apr 01, 2008
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Dear Sir The dvd cannot read the disc
One of the problems with many DVD players is as they get older the spindle motor is unable to overcome the inertia of the spindle + the disc.
If this is the case the read head will try to hunt for the start of the DVD if it is not spinning then it wont be able to find the DVD. If you can access the DVD by taking the cover off you can give the DVD a chance to spin by giving it a little push if the player can find the DVD then you can watch the movie.
If this is the case you will need a new spindle motor fitting to your player.
Jan 06, 2010 | Polaroid PDM-0742 Portable DVD Player
Player does not read disc-code HO3
I followed a few, of the already suggested answers. The first one I tried was to open up the back and use compressed air to blow out lint, food crumbs and dog hair that had found there way into the machine. This seem to have worked just fine. Now the machine is working, much to my daughters delight.
Sep 29, 2009 | Panasonic DVD-LS90 Portable DVD Player
Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Sep 18, 2007 | Audiovox D1812 Portable DVD Player
Dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
May 15, 2007 | Coby TFDVD5000 Portable DVD Player
Reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Jan 29, 2006 | Panasonic DVD-LV70 Portable DVD Player...
Panasonic DVD-LA95 Portable DVD Player Logo
523 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
