Question about Frigidaire GLMV169D Microwave Oven
Door Handle Broken Off
The plastic around the interior fasteners broke and the door handle is completely off. The top fastener fell down into the door and the other is still in the door but not functional.
I assume I would need to take the door apart as in the previous response to the question about a spider between the panes. Can I buy the handle and install it myself if I'm a reasonably mechanical guy?
  • Frigidaire Master
  • 9,125 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 21, 2008
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
My samsung SMH7187STG microwave handle broke off.
You can order new "cap handles" (the plastic parts that join the aluminum handle to the door for 3.99 each plus 8.99 shipping and handling at the Sears Parts Direct Website. The part number is DE67-00222C. When you have the parts in hand, open the microwave oven door. On the inside surface of the door their is a black plastic frame around the door that pops off easily (gently use a screw driver to pry up the door frame) so that you can have access to the screws that attach the end caps to the door. You will need to hold the remant of the cap handle (the part that is probably broken off even with the glass surface on the outside side of the door) still while you unscrew the screws. Once the screws and broken remnant of the handle caps are out, you are ready to put new handle caps on the handle, then put the handle with the new handle caps on the door. By the way, Samsung was absolutely NO help with this. The agent I chatted with denied that their were any reports of the handles breaking off, so I had to cut and past the postings about the door handle breaking off ON THEIR OWN WEBSITE under "Community Q and A" into the chat box -- still the agent did not acknowldege the existance of these reports...or the possibility of a poor design. I asked for them to send me a couple of the $4 parts as a good will gesture....got nothing but lofty words about Samsung commitment etc. and only a authorized technition blah blah, no action. All you need is a strong thumbnail, a phillips head screw driver, new handle caps.
May 02, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
Handle broke off my GE Advantium 120 microwave door (model #SCA1000DCC03). I just ordered a replacement handle (PRT #WB15X10071) but I need instructions on how to replace it. The screws are hidden inside...
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Sep 16, 2009 | GE Advantium 120 Convection/Microwave Oven
Door Handle
If at all possible try getting an exploded image break down to see what needs to happen, basically you have two things in your way one is the "choke"...the large black rectangle on the inside of the door this has to be pryed off carefully all the way around and lifted off, pocket knife works great to get it started. next you will have the front door assembly snapped onto the mesh screen and frame of the door itself. Once you have seperated the front door you will see the screws for the handle, DONT OVERTIGHTEN these screws when you reinstall.
Hopefully this video clip
Aug 26, 2009 | Frigidaire FMV156EM Microwave Oven
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Broken handle
Almost all microwave ovens manufacturers locate the handle mounting screws behind the inner black plastic frame known as the 'choke'. If done very carefully, the choke can be removed with a putty knife without breaking it. My suggestion would be to order a handle and a choke. HOWEVER ordering a complete door will be less aggravation and not a lot more money. The handle and choke will cost around $120.00 whereas a complete door goes for around $130.00. Check out www.searspartsdirect.com for more detail.
Feb 03, 2009 | Frigidaire FMV156DC Microwave Oven
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
then
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace GE Spacemaker XL1400 door
On most microwavre ovens all you have to do is open the door all the way and lift straight up at the hinges. The door comes right off the hinge pins. In some cases you may have to remove the top louver panel (right above the door). You should NOT have to unmount the oven to complete this. In fact...I would not recommend it.
Is this a simple matter of replacing a door handle? If you need to only replace the door handle, you just lift slightly on the INNER door plastic around the glass and you will be able to access the door handle screws. There are a series of small grooves in the panel that you can use a small screwdriver to gently pry. You should not have to remove the entire panel. Just open it enough directly behind the door handle. Be careful when prying on the plastic. It can break if you're not careful. I hope this helps you.
Feb 27, 2008 | Microwave Ovens
Broken door handle
bogus...use a Torx driver to remove the door screws...careful of the glass. Replace the handle and reassemble. You may want to take digital pictures along the way. Parts available from ge or other online parts guys.
Dec 18, 2007 | GE Advantium SCA1000H Convection /...
How do disassemble the door in JVM1850B
You can find helpful exploded view diagrams by entering your model number here: http://tinyurl.com/gv383
Sep 06, 2007 | GE JVM1850 1000 Watts Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
197 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Jim Goldsmith
Jim Goldsmith
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
