Question about Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is in for repairs
On 7/21/08 I took my 42''tv in for repairs to a Philips cert. repair shop and they are having problems getting the wright parts. The shop keeps telling me the parts take about a 4 weeks to receive parts and this time 11/28/08 the wright parts should have arrived and still as of now 12/19/08 still, no TV. Are parts this hard for a independent TV repair place to receive from Philips?
Thanks, Dan Moore
  • danosden Dec 19, 2008
    The TV is out of warranty and it's a small Ma & Pops shop and it sounds like they are trying but 5 months to fix a tv.
    Problem Solver:
The parts come Vance Baldwin I just ordered a logic board from them for my plazma and it took 4 day's
Posted on Jan 03, 2009
    President:
  • 2,992 Answers
It depends on the parts availability from Philips and also partly on how much business the shop does for them. When I worked for a big retailer on TV service, we had problems with RCA sometimes not being able to supply parts. Then when they finally had them their "official" service centers got them first. While the shop may be feeding you a line, they may really be having troubles. If they are a certified center, they should have a Philips rep they can deal with to try expediting the part. You didn't mention whether this is a warranty repair or if you're paying; if it's warranty they (Philips) should be trying to get you done faster so you'll stay a happy customer.
Posted on Dec 19, 2008
  • 2,336 Answers
If they are an authorized philips service center, they should know by now if parts are available. If the TV was still under warranty when you took it in for service and philips is unable to provide parts for the repair, they should give you another TV.
Good Luck.
42 inch plasma tv
Power supply needs repair.Est in range of $150 is fair. Find a qualified shop
May 12, 2010 | Philips 42PF9631D 42 in. Plasma Television
I have a Phillips 42 inch Plasma. I tried
One of two issues/problems:
1) Main Power supply problem
2) High Voltage Power supply problem.
A Good TV Service Shop that works on Philips would be the first place I'd call. It will be much cheaper to bring the TV into the shop instead of having a tech come out to your location.
Possibly a $200 to 300 dollar repair.
Blessings,
A/V Media Guy
Nov 23, 2009 | Televison & Video
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Sep 03, 2009 | Philips 42HF7444T 42 in. Plasma TV
Crack on the inside screen of my 42" Philips Plasma TV
This is a known problem with Philips. If you keep on them they will work with you. Another option is call a repair shop in your area and see if they can help you out. Sometimes a repair shop will help out if you allow them to do the service if they are able to get Philips to pay for the repair.
Good Luck
Apr 21, 2009 | Philips 42PFP5332D 42 in. Plasma...
42 plasma philips
All you can do at home is leaving the TV unplugged for one or two hours and see if this solve the problem.
If the unit has just been repaired, and it is faulty again, contact the service back and have the problem fixed.
Common faults on plasma TV can concert the PSU power supply board, the sustain boards, and other boards, wiring and connectors.
The testing and repair job must eb done by a technician.
Dec 19, 2008 | Philips 42PF5521D 42 in. HD-Ready Plasma...
42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
Oct 23, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips switching off
Take it to repair shop ,unless you do TV repair! this is not a easy fix it yourself problem it will need to be repaired.ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Philips 42FD9934 42 in. HD-Ready Plasma...
Philips plasma
I had this problem. If you are saying it happened on your plasma screen rather than the receiver box, then the problem can be that the power source inside the plasma needs to be replaced.But Philips will charge a fortune for just looking at the TV. So you might as well take it to your local repair shop.
Jan 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Philips 42PF7320A 42 in. Plasma HDTV Logo
159 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
