Question about Saitek ST290 Pro PC Flight Stick [ PS23 ] (117054)
ST290 Pro internals
I'm looking for any info on the Saitek ST290 Pro PCB. Wiring diagrams for switches, connections etc. I've noticed that it has several more connection points (J2-J5) that look like additional switches or pots could be added. I'd love to know what they're for. Anyone got any inside info?
I'm planning to remake the stick to suit my particular application. I just like to tinker.
AMSATX
  • 27 Answers
SOURCE: Need for Flight Simulator Manual for Saitek ST290 Joystick.
you may get it at: www.flightgear.org
Posted on Jan 01, 2008
AMSATX
  • 27 Answers
SOURCE: I need a manual for your Saitek ST290 Joyhstick; can you supply one to print?
you can get a free manual :
you have to log on to www.saitek.com and have to become free member by providing your general info. like email id thats all . you will get any manual for free.
AMSATX
  • 27 Answers
SOURCE: SAITEK ST290 JOYSTICK USB disc
you can download from www.drivers.softpedia.com for free.
yes it is compatible with vista.
you may try for: www.opendrivers.com
Cee64E
  • 18 Answers
SOURCE: Saitek st290 Lube
I'm going to assume that you're refering to the central spring slider on the stick. The spring follower at the base has to slide up and down the shaft to provide spring pressure as the stick moves away from center. This plastic follower has a tendancy to gall the plasic it slides over on the stick shaft resulting in jerky stick movement. You can solve this problem with any wax based lubricant. I used a chapstick, but there are sprayable wax lubes that would be easier to apply, you can find them at hardware stores. Be careful with oils. Plastics are made from oil and the wrong ones will disolve it. WD-40 is a safe oil but use it sparingly and only on the shaft. Avoid using penetrating or cutting oils, they will disolve the plastic. You should test any oil on a foam coffee cup.
The stick's internal gimbals are already well greased and don't need relubed and the throttle is supposed to be a little stiff. I've had good results with both WD-40 and waxes. The waxes are a little harder to apply but last much longer
Posted on Dec 19, 2008
Cee64E
  • 18 Answers
SOURCE: Trigger button on Saitek ST290 is stuck in fire position
I've disassembled the ST290 to get at it's internals. It wasn't easy. It's not something I would recommend and finding the exact same lever switch to replace the damaged one would be tricky, not to mention soldering in the new switch and all.
I have seen the ST290 at Radio Shack stores for less than $20. You might be less frustrated just getting a new one.
What games does this work for
all microsoft flight simulators that accept usb game controllers will recognize ST290 usb joystick.
Aug 11, 2010 | Saitek ST290 Pro PC Flight Stick [ PS23 ]...
Aileron control
You didn't say what game you are using this in. Many flight sims allow you to setup controls more specifically and to your liking. I would look for such a menu in game and reverse that axis.
Oct 23, 2008 | Saitek ST290 Pro PC Flight Stick [ PS23 ]...
May 27, 2008 | Saitek ST290 Joystick
XP Pro doesn't recognize the ST290
You do. I had absolutly no problem with it when i jad windows.
Mar 20, 2008 | Saitek ST290 Joystick
Not working help
joypad doesn`t work well ob fifa 09
Jan 19, 2008 | Saitek ST290 Joystick
Dec 28, 2007 | Saitek ST290 Joystick
Nov 25, 2007 | Saitek ST290 Joystick
Games
You should be able to play any game out there, if you are unable you may need to update your drivers. Hope this helps:) Jason
Sep 04, 2007 | Saitek ST290 Joystick
Saitek ST290 Pro PC Flight Stick [ PS23 ] (117054) Logo
101 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
