Suddenly printer will only accept paper from manual feed. I have opened & closed the manual paper feed door several times, printed using the manual feed and reloaded the tray several times. Read through manual and looked at Help but am running out of ideas. HELP!
Thanks.
Bob
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Brother Fax Machines:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted.
same problem and the Job Cancel wont work, can receive faxes though
I have the same problem and setting it to feed tray doesn't work, nor does job cancel.
