Question about Plumbing
Eljer slantback lavatory faucet
I am unable to pull the outer chrome plated handle of the faucet hot water cutoff (06890630 part no.) from the brass adapter (06890550) underneath. Normally, the metal retainer (06890552) can be pushed in, and the chrome handle (sleeve) will pull off. It appears to be corroded to the brass unit adapter. I have drilled a hole above the adapter and squirted liquid wrench over the top of the adapter, but am still unable to get the two parts (handle and adapter) to separate. Therefore, I cannot remove the stem and bonnet assembly to repair it.
    Novelist:
  • 148 Answers
Use baking soda to remove the corrosion mix a little in apaper cup and brush on with toth brush
I do not have a clear picture but can you not put two screw drivers under the lip of the chrome and pry up
One other thought is to tap the top adapter with a hammer to see if it will break loose
Posted on Dec 30, 2008
Do you have a handle set with a 7 inch spread instead of a 8 3/4 spread and model #
Yes we do. how many would you like?
  • Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount ... www.amazon.ca/Kingston-Brass-CC543T8-Vintage-7-Inch/dp/B0026ZPI0Y
    • KINGSTON BRASS
    Kingston Brass CC543T8 Vintage 7-Inch Spread Wall Mount Leg Tub Filler with Hand Shower, Satin Nickel in Showerheads & Handheld Showers.
  • Kingston Brass KB967 Magellan II Widespread Lavatory ... www.amazon.com > ... > Rough Plumbing > Faucet Parts > Faucet Handles Kingston Brass KB967 Magellan II Widespread Lavatory Faucet 8-Inch to 16-Inch Centers 7-Inch Spout Reach, Satin Nickel and Polished Chrome
  • images of 7 inch spread faucet bing.com/images th?id=oip.m9aaf750d3da8ce6a24cbe32ef9078ae8o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m643aef6e35c24789db3419b21dd47a91o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.ma09426c72dcc25d64ff92045ab194af1o0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9b0dc70d9ab53ad1ecca18fd130db74bo0&w=103&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m9afd6495c16d35699054f30b9ee4d7e7o0&w=104&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of 7 inch spread faucet
  • Water Creation F6-0007-05 Vintage Classic 7-inch Spread ... www.overstock.com > ... > Bathroom Faucets > Water Creation
    • 5/5
    • 1 RATING
    • $409.17
    Shop for Water Creation F6-0007-05 Vintage Classic 7-inch Spread Deck Mount Tub Faucet with 2-inch Risers and Handheld Shower. Get free shipping at Overstock.com ...
  • Apr 16, 2016 | Plumbing
    Hot water handle is loose, how do I fix?
    The link to the parts diagram is attached for your reference. It seems that you can tighten the handle by turning it.
    http://www.totousa.com/Portals/0/ProductDownloads/PD-00379_TL794DDLQ.pdf
    Jan 09, 2014 | Toto TL794DDPB Nexus Widespread Lavatory...
    Moen ca87553
    You need a #1225 replacement cartridge. Pop the cap off of the handle. Use phillips screwdriver to remove the handle screw. Pull the handle off. Next, unscrew the two screws holding the cover plate on. After removing plate, there should be two integral stops, one on each side of the valve. Close the valves using a straight slot screwdriver. Pull on the brass cartridge spindle to ensure that the water is off. Remove the stop tube, which is a chrome cylinder at the center of the valve body. Look for a brass retainer clip at the top of the cylindrical portion of the valve body where the handle connects. It has a small hole and after you pull it out, you will see that it horse shoe shaped. Use your pliers or an awl stuck through the hole to pull the clip out. Note the position of your cartridge. There is a notch on the end of one side of the brass spindle at the center of the cartridge. Make note of its position. If you install it and get hot and cold reversed, just take the handle back off, and spin the brass spindle 180 degrees. The replacement cartridge comes with a white plastic tool designed to make removal easier. Use it. After loosening with the plastic tool, take your pliers and grab the brass stem. Pull as straight as you can. If cartridge will not budge, you might need a Moen cartridge removal tool. Do not spray with WD-40 or Liquid Wrench unless you like that taste in your water. If your clip won't go back on, it's because you didn't align the two ears on the cartridge. The ears should be at three o'clock and six o'clock. The cartridge must also be pushed in all the way. Good luck!
    Dec 08, 2013 | Moen 3175 Legend One Handle Shower Faucet...
    Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
    If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
    Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
    The hot and cold water handles both turn clockwise. Can I get the hot handle to turn counterclockwise so that you can turn both on by pulling the handles forward?
    some manufacturers do that but if its new and you still have the box return it as faulty or get yourself a new cartridge for the hot hot is always on the left or should be
    Dec 04, 2010 | Danze & Bannockburn™ Two Handle...
    I have two brand new Price Pfister 042-VGCC faucets and the cold water side comes out really slow. All other fuacets work great and hot water is fine. I disconnected at the valve under the sinks and there...
    MOST LIKELY YOU HAVE A CLOG AT THE SEAT ON THE INSIDE OF THE FAUCET, TYPICALLY SAND, PEBBLES, OR PIPE SEALANT. TURN THE WATER OFF, UN-SCREW THE HANDLE, REMOVE THE SET SCREW LOCATED INSIDE THE HANDLE BODY, PULL THE HANDLE BODY UP, LOOSEN THE NUT, REMOVE THE SEATS AND STEM AND UN-CLOG THEM.
    Dec 15, 2009 | Price Pfister 042-VGCC Polished Chrome...
    2-handle faucet handles both rotate "on" counter=clockwise
    Here's the solution from Delta:
    On a two-handle kitchen or lavatory faucet, if the handles rotate in the wrong direction, simply rotate the right stem stop assembly 180 degrees. This will change the rotation of the handle to the other direction.
    Jun 23, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
    Mine leaks handle and cap (housing cartridge)
    there should be a little cap covering a allen srew in the front or back of the handle it sometimes looks like the hot or cold sign or chrome pop that off and loosen the screw and pull off the handle there should be a nut loosen that and pull up the cartridge you might be able to find one at home depot be sure to turn the water supply off
    May 20, 2009 | American Standard 2175.502.002 Colony Soft...
    Eljer lavatory faucet will not shut off. Chrome knob is stuck.
    If you are trying to remove the handle you need a handle removal tool sold at all hardware stores
    Nov 10, 2008 | Plumbing
    Plumbing Logo
    566 people viewed this question
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
