Question about Toshiba TDP-S8 Multimedia Projector
Toshiba Projector won't turn on!!!
My Toshiba TDP-S8 was off for about 3 months , but plugged in and now won't turn on. The power light blinks only. It had worked fine before. Only about 200 hours of lamp usage. What is the problem?
Victor
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Posted on Dec 28, 2008
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
TD9-S81 no power when data projector comes on
no leds? bad power supply. leds but no fans? bad button panel or main board. led and fans but no light? colorwheel or ballast.
Sep 18, 2009 | Toshiba TDP-S81U DLP Projector with...
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-T90 projector - Won't turn on
the power supply capacitors are dried up. replace the power supply.
Jul 29, 2009 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Will not turn on at all
you will probaly needs a new power supply in it. make shure that your getting power from outlet to. Hope this helps
Jan 13, 2009 | Toshiba TDP-ET20U DLP Projector
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Aug 23, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S8 Multimedia Projector Logo
1,399 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Computer Links
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
