Question about Kitchen Ranges
I have a Carlton C60FX built in oven that is only coming up for two years old. It has now decided it isn't going to cook my christmas turkey. The grill works fine and the fan blows, but the oven just won't heat up. Please please someone come back with a quick solution so i can get onto this asap. With christmas barely a week away i am not even sure i will be able to get any part that is needed before then. A contact phone number for Carlton manufacturers would be great
MicrowaveSvc
  • 9149 Answers
SOURCE: Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 25, 2007
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
  • 1462 Answers
SOURCE: Miele Oven H316 When using
element should glow dull red when on fan oven but not bright red. are you sure fan is operating? remember there are two fans - oven fan and casing fan and you may be listening to casing fan
Posted on Nov 17, 2008
SOURCE: Oven shuts off
replace oven temp.sensor
Posted on Nov 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Faulty electric oven (Ignis AKL828/AV)
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
How long do you cook a turkey in a Hamilton Beach roaster oven and what temperature
Hello Angela Couch,
You treat the Roaster like any other oven...
Off the TOP OF MY HEAD...
More importantly... The TURKEY must be thawed properly to be cooked properly.
I FIGURE 23 to 25 minutes per pound at
325° F... If Stuffed add a of pound of cooking time for each pound added by stuffing
Monitor closely with your MEAT THERMOMETER...!!
Your turkey is done when the temperature with a meat thermometer is 180° F in thigh and 165° F in chest or stuffing.
Take your instructions from the TURKEY...
(Altered appropriately by STUFFED or NOT
STUFFED) and backed up with a good
QUALITY meat thermometer...!!
BUTTER-BALL has one of the very best
on-line cooking calculators...
How To Roast Turkey Butterball
Proper left-over handling is also very important
Bon appetite & Merry Christmas!
Carnac the Magnificent
Dec 20, 2017 | Hamilton Beach Kitchen Appliances - Others
I have a 24 pound turkey that I want to cook in the roaster oven over night. Can this be done and how?
You can, but cooking overnight will ruin the turkey. The bird will be overcooked and literally fall apart. The term is called 'cooking to rags'. The bre asttt meat will be very dried out.
Unstuffed is only 4 to 4 1/2 hours. Stuffed is 5 to 5 1/2 hours. I only stuff the neck end. Another tip is to cook the turkey bre asttt down. If you do it that way, all the juices from the fattier part of the turkey, the legs and thighs bastes the bre asttt as it cooks. If you cook it this way once, you will do it every year. Turn the bird over to carve it once it has rested for 20 minutes. Tent it with foil. Put folded foil over the wings. I am a trade masterchef.
Turkey Cooking Time Guide Allrecipes Dish
Nov 24, 2016 | Kitchen Appliances - Others
I have a 30 qt pot, cooking a 18 lb turkey. placed turkey in pot and added water. amount required is above maximum limit level. Can I exceed?
If you are frying it, no you can't. As moisture comes out of the turkey, it will cause the fat to boil over.
You say you 'added water'. You are making boiled turkey for Thanksgiving? You could, but not the same.
I have two suggestions.
Cook traditionally in the oven. I am a chef and have cooked my turkeys breas t side down for a bout 20 years. The result is a much moister breas t on the turkey.
or
Split the turkey and deep fry in two batches.
The word breas t is considered as profanity on Fixya. Please review your answer and try again.
Nov 25, 2015 | Bayou Classic Kitchen Appliances - Others
Where can I go to get a user manual for Carlton C17GSS09 microwave
Is thisa the 39 Pound special?
Try Curries in the UK they are cheap units made for sales as specials.
Beware tho if they break down tjhey are considered throw away.
Capacity - 17 litres, Microwave wattage - 700W, Grill wattage - 1000W, External dimensions WDH(mm) - 440x318x252, Stainless steel door with silver casing, Power levels - 5, Auto programmes - Defrost/cook, 8 auto cook programmes
The cheapest price Currys for CARLTON C17GSS09 is £39.00. For more information on CARLTON C17GSS09 please visit their online store.
CARLTON C17GSS09 is available from as little as £39.00.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Microwave Ovens
I have a master built gas frier and just tried to cook a turkey and it didn't work. It took about three hours to come up to 360degrees. Put the turkey in and temp dropped to 225 and stayed there. cooked...
http://www.masterbuilt.com/manuals.aspx?search=M30BV
something is wrong if you followed the manual. I would get in touch with Masterbuilt directly
customerservice@masterbuilt.com
Phone
1.800.489.1581
706.327.5622 (local for Columbus, Georgia)
706-660-8022 (fax)
Address
Masterbuilt Mfg., Inc
1 Masterbuilt Court • Columbus, GA 31907
Nov 27, 2009 | Masterbuilt M30BV Deep Fryer
Can you cook a stuffed turkey in the roater oven
Yes, similar timewise to a regular oven. But it depends on the size of the turkey, if stuffed you definitely want to check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound unstuffed turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. It adds about 1-2 minutes per turkey pound if stuffed.
All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 21, 2009 | Hamilton Beach Toaster Oven with...
Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
May 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Big 18 pound turkey and no manual
Place turkey on trivit in roaster and add 2 cups oof water. place lid on roaster and seal edge with foil. Preheat oven to 500 degrees.  Place in oven for one hour and turn oven off and go to bed.  Turkey will cook while temperature is coasting down.  Turkey will be still warm in the morning.  We have been doing this for several years and always comes out golden brown and juicey.  Do not stuff bird while cooking.
Nov 30, 2008 | Rival 18 Qt Roaster Oven with Buffet...
No heat
Hi.
If your oven is less than a year old, then you should contact the store where you purchased it from or contact the manufacturers service department , as it should still be under guarantee.
Hope you get your problem solved.
Cheers
Nov 27, 2008 | Ovens
16Qt Roaster oven
Dear Lunders
I cannot recommend cooking a turkey in a crockpot for many reasons. I have always cooked turkeys at 200/225 degrees in the oven overnight. The secret is to seal the roaster with heavy duty foil with maybe a cup of water in the roaster, bake the bird upside down. Turn it over, increase the temperature, and uncover it for an hour before serving. Worked for me for 40 years, and the guests never complained.
Ray
Nov 27, 2008 | Crock Pots & Slow Cookers
Kitchen Ranges Logo
115 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
