The water in the washer won't drain.
In the middle of a washing cycle, the water didn't drain.
  • Anonymous Feb 15, 2009
    Where the filter so I can check it and clean it????
  • 157 Answers
Check pump/filter
Posted on Dec 19, 2008
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Washer quit working in middle of cycle, won't even come on
Look under the washer. Is there a little pile of black rubber shavings? With the heavy load, you may have broken the basket coupler between the motor and the drum. Try turning off the selector, and move it one click at a time towards the end of the cycle and turning back on. Hopefully it will drain for you. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum.s-l225.jpgs-l225.jpg I attached pictures of a couple types. This part is a common problem when you put a heavy load in, because the rubber takes more stress.
Jul 09, 2017 | Frigidaire Affinity ATF7000E Front Load...
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Floods floor when on rince cycle Program Bed andBath. Fault intermittant
If you didn't flood the floor when the washer emptied on the wash cycle, it is more likely that you have a partially plugged up drain than a malfunctioning washer!
Has you drains been cleaned lately, being the spring time you might have a root problem partially blooking the drains.
Watch you washer, if the washer flushes the water down the drain line it is working. If the water comes over the top of the drain line, then you have a slow drain.
Jun 01, 2011 | Washing Machines
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
226 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
