Question about U-Line Icemaker
Standalone icemaker sounds like a Harley Davidson
Still making ice but making a very loud sound like a Harley Davidson is sitting in my kitchen. The sound will stop periodically or I can make it stop temporarily by turning the machine off, then back on. Soon, however the Harley returns. Sometimes it sounds more like a distant chain saw - also a comforting sound. Does anyone have any ideas?
    Problem Solver:
  • 10 Answers
Check and make sure you don't have a piece of scale in the intake of the waterpump. the pump stops when the unit goes into defrost to dump the ice onto the cutter grid. also check the fan under the icemaker for lint buildup on the condensor
Posted on Dec 19, 2008
Could some please post how to remover the ice maker from my kitchen aid model ktrc 19 m refrig thank you
Look right above the icemaker part that forms the cubes. Its usually brown in color, Just above it are 2 extensions of that brown part that has 2 screws going into the left side of the freezer, Remove the 2 screws and the unit comes out. The power plug for it is just to the back bottom of the ice maker. If you can see it you can probably just unplug it to stop the noise.
Apr 11, 2015 | Refrigerators
Icemaker making noise
check that there isn't any ice stuck inside the icemaker teeth.
Apr 24, 2012 | Whirlpool Ice maker 4317943
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Ice make make loud sounds and doesn't make much ice
First, you should have a warranty, check to see if it is still in effect. If expired, then can you describe the sound, and about how often? Also check the freezer temp. it should be 0 deg or below for proper icemaker operation. The colder it is, the more ice is produced in a day. And yes, if the mold heater isn't working, the thing will raise hell when it tries to cycle.
Jun 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Muffler
If you mess with those mufflers you are goin to loose back pressure and your bikes performance will suffer. Get some slip ons , Vance and Hines, or Rinehart or Sampson. You'll get the sound you want and your performance will be enhanced as well
Dec 03, 2008 | Harley Davidson Harley-Davidson Motorcycle...
U-Line Icemaker Logo
173 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
