Question about Mitsubishi WT-46809 46" Rear Projection Television
I have a Mitsu WT-46805. The convergence IC has gone out.
I understand the the replace part is a STK392-040. The only similar part I can find in town is a NTE7178. Are these part compatible?
  • 1 more comment
  • keldodgs Dec 31, 2008
    I have
    I have the same convergence problem - I am looking for directions on accessing the IC chips, process to identify which on is defective, and how to replace.. is there a document that I can read, additionally some functional diagram/schematic that I can look at to find the chips in questions? Thank you very much..
  • kelly_small Dec 31, 2008
I wouldn't use a generic replacement part, use only original OEM ( cost is about $25,00 each) you can check at Electonic Part Cos such as Pan-Son or Dalbany and( there's a big Commpany down in Miami, sorry I can't remember the name of it) and make sure you clean off the heat sink grease ( white pasty stuff ) and replace it with a sufficent amount of new grease, these IC's disapate lots of heat and that what causes early failure
Posted on Dec 28, 2008
Mitsu wt42313 error 22 any ideas?
error 22 "short protect circuit"
Bad convergence IC, also replace 5A picofuse.
Dec 29, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I think that you have two that are on the board in the center of the set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
May 29, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 convergence resistor location and vlaues
5a resistors are all 120 ohm 1/2 watt use flame proof resistors.
check fuse f9a23 or f9a22
also replace knowen bad caps in this unit efecting convergence replace all 10uf @ 16v on the scan doubler module, ther are 8 off them.
make shure and check trace between Rg-8 and r705 for a open, sumtimes fulid from crt will open this up.
regards
daniel.
Jan 13, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsu 805 red grill problem
Needs convergence amp IC's STK392-570 replaced = common repair for qualified Mits tech..........T.
Nov 09, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Mitsu 46805 - No picture
this model has loose connections on the yokes remove the front speker gril and a small cover wigil the wires alittle and see if the pic comes back on if so solder the bad connections and put fresh solder on the verticl ic too
Oct 18, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
