Question about Kenmore 96012 / 96014 / 96019 Electric Kitchen Range
Fuse from with old kenmore range
I have a noise coming from the panel where the clock and burner controls are. when the fuse for the clock is removed the noise stops. i have replaced the fuse but the noise returns. its almost like a humming/rattle. Help. thanks, susan.
My GE range had the same problem. There was an electrolytic capacitor on the timer board that failed (100uf at 50 Volts). It is next to the board's power transformer and part of the DC filter circuit. If you don't know what this means, perhaps an electronic tech can help you. Anyways, it is repairable, though proper skills required.
Posted on Jan 22, 2011
  • 61 Answers
There is an internal component in the clock that is probably responsible for the noise not much can be done other than changing the clock. Also try tightening all screws on the clock. good luck
Posted on Dec 19, 2008
Kenmore model#790-78868800
Could be an open fuse or loss of power at the outlet.
Jul 28, 2016 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a Kenmore electric range with burners not a flat top. The clock and the oven light work. The ovven and the burners do not work. I have reset the breaker. Could one side of a breaker burn out? Thxs
Yes, one side of a double pole circuit breaker could go bad, but unless you live in a really old house it isn't likely. Instead of just replacing the circuit breaker, $30+, you might want to check with your neighbors and borrow a multimeter to check the outlet to see if you have 120 volts on each leg of your outlet (which makes up the 240 volts you need). If you have 120 volts on each leg then your breaker and outlet are functioning.
Some ranges have an internal fuse that controls the heating elements. Suggest you go to www.searspartsdirect.com and plug in the model # off the equipment id tag (on rear panel or on oven frame) and check to see if there is a fuse or fuseable link.
Sep 09, 2011 | Kenmore Kitchen Ranges
I have a old whlipool range. The control panel says F2 E1. I cannot fix the panel to the clock or bake etc etc. However the burners come on and it keeps beeping. I had to unplug the stove. What can I...
F2 - E1 Keypad cable unplugged 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 16, 2010 | Whirlpool Kitchen Ranges
Clock and oven light comes on when burner control is turned on.burner does not heat up.
unplug range ..remove the back panel on the range..1/4 in srews need to be removed to see all them wires ..one of them is burnt together i bet causing this to happen ..if not the switch is bad /or the burner socket /burner .use a flash light to see sockets look good all connections all switches ..let me know /joe
Aug 27, 2010 | Jenn-Air JES8850BA Electric Kitchen Range
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Jul 19, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Kenmore 96012 / 96014 / 96019 Electric Kitchen Range Logo
194 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
