I have a probolem with my icon 225 usb modem runnig to slow
  • 111 Answers
Camera modems generally max at 56k for fax check your settings and download a updated usb driver for the camera
Posted on Dec 19, 2008
When I connect a USB modem it does not connect to internet.
check the status of driver in device manager whether its detecting or not
Jul 26, 2011 | Computers & Internet
PQI U273 4Gb Flash Drive not recognized by Win 7 after first use.
neved alapj?n ?rteni fogod magyarul is, legal?bbis rem?lem.
az a probl?ma, hogy win7 driver egyel?re nem l?tezik az eszk?zh?z (a gy?rt? nem is ?rja, hogy t?mogatn? ezt az op-rendszert. a (nem t?l eleg?ns) megold?s az, hogy haszn?lat ut?n el kell t?vol?tani el?sz?r a pendrive-ot, majd az eg?sz usb-hubot a rendszerb?l (term?szetesen csak szoftveresen: device managerben uninstall), majd ezek ut?n ?jrabootolni. ekkor a win7 ?j hardverk?nt felismeri a hubot ?s az ezek ut?n ehhez csatlakoztatott pqi u273-ast is. persze ism?t csak egyszer...
http://www.pqi.com.tw/faq_1.asp?ID=1579
Dec 28, 2010 | PQI 8GB PQi U273 USB 2.0 Drive Metallic...
My internet connection is too slow...i use usb modem(pldt weroam plus)how to make it fast?
Some of the tips to increase internet speed on your USB modem are,
* Place your computer at an elevated place, such as upstairs or near a window. Also, select an open space as your work area instead of an enclosed area bounded by walls. Walls block out the signal, which can cause the Internet speed to slow down.* Access the Internet at a hot spot where your network carrier offers the best network signals.* Connect a clip-on antenna to the USB modem. A number of signal booster antennas, which are designed for assisting USB modems in connecting to distant networks, are offered on the market.* Access the Internet during off peak hours
* Contact your Internet service provider and ask them if you can get a higher bandwidth for your USB modem. If so, inquire about the price. If it sounds reasonable, then you might want to consider it.
Check your internet speed from www.scanmyspeed.com after following these steps. you may find a difference.
Oct 22, 2010 | Computers & Internet
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
TedMac
Sep 18, 2010 | Computers & Internet
Jjádf, jádfkj ábdkf ákjdfu aksu káudf adsfá df ádf d
Can you restate your problem, in English, or French, or German, or Spanish, or Norwegian?
Jun 12, 2010 | Asrock P4I45GV...
La direccion de la consola esta deshabilitado mac xbox360
Conectar xbox 360 a internet; si tienes xbox 360 y quieres jugar en internet, ve este tutorial.
Como conectarse al Live.
Bueno tienes tu nueva 360 smile.gif y ahora quieres entrar a la experiencia Xbox Live y no sabes cómo. Acá una guía que te enseñara como hacer desde las conexiones de redes (VTR por ahora) hasta la creación de tu cuenta Xbox Live/gamertag.
Las Conexiones:
Hay 4 opciones para conectar tu consola:
A: Directamente desde el MODEM de VTR.
Conecta el cable de red que sale del MODEM a la 360.
MODEM ------------ 360
1. Llama a VTR (600 600 9000 opcion 3, 3), pideles que te cambien el numero de MAC al que tiene la 360.
2. Para saber como obtener tu numero de MAC debes buscarlo en las opciones del menu de 360
3. Una vez hecho esto estás listo para entrar a Xbox Live.
B: Desde el MODEM de VTR 2 conexiones (USB y RED).
MODEM red ------------- 360
usb ------------- PC
1. Conecta el otro dispositivo que tengas (Ej. PC) y conectalo via USB.
2. Conecta la 360 por el Cable de Red.
3. Llama a VTR (600 600 9000 opcion 3,3), pide que te registren 2 MACs, la del PC y la 360. Así ambos quedarán con Internet.
4. Una vez hecho esto estás listo para entrar a Xbox Live.
C: Router
Modem ------- Router ------ 360
1. Conecta la 360 al router con un cable de red.
2. Ahora hay que configurar el Router. (Ruteo de puertos)
1. Tienes que entrar al menú de administración del router. Generalmente la dirección es 192.168.0.1, después te pedirá nombre y contraseña. Generalmente es User: admin, sin password. Si no funciona, vas a tener que conseguirtelos.
2. Una vez dentro del menú.
3. En la página eliges Forwarding.
4. Elige la marca de tu router.
5. Elige Xbox Live 360
6. Sigue las instrucciones de cómo “rutear” los puertos para la 360 (88 y 3074)
7. Una vez ruteados los puertos, estás listo. Empieza la creación de tu Gamertag.
D: Router via Wifi
Router )))))))) 360
1. Necesitas el Adaptador Wifi para la 360
2. Necesitas un router con soporte Wifi b/g
3. Prendes la 360 vas a la parte de Sistema – Config de Red – Windows Connect Now.
4. Eliges el Spot Wifi
5. Desde un PC, Ahora hay que configurar el Router (Ruteo de puertos).
5. Elige Xbox Live 360, Sigue las instrucciones
6. Una vez hecho lo anterior, estas listo para crear tu Gamertag.
XBOX LIVE
Entendiendo Xbox Live:
Primero hay 2 tipos de cuentas para Xbox Live. Gold y Silver.
SILVER
• Permite a otros jugadores saber quién eres y cómo juegas gracias al perfil de jugador único.
• Entra en el Bazar Xbox Live para conseguir fantásticas descargas (incluidos los juegos clásicos de consola de Xbox Live Arcade), demostraciones y tráilers de los juegos que van a salir próximamente.
• Prueba la acción multijugador con acceso a partidas multijugador masivas. Lo único que tienes que hacer es crearte un gamertag.
• Disfruta de la acción multijugador sin límites con las oportunidades suscripción de prueba al nivel Gold.
• Crea y mantén una lista de amigos para conectarte y comunicarte instantáneamente con familiares y amigos mediante mensajes de texto y voz.
En otras Palabras... Puedes Bajar Trailers, demos, etc. Pero NO puedes jugar Online
May 20, 2010 | Microsoft Video Game Consoles & Games
My 3g usb modem is installed but it doesnt come up, and i cant connect. i click on the icon but it doesnt come up
that happened to me, i fixed it by uninstalling the program and also going into device manager and uninstalling the drivers for the usb modem, after that restart and plug the usb modem in and install the program, good luck
Oct 16, 2009 | Computers & Internet
Unable to connect Tata Indicom USB Modem on MacBook Pro
insert usb modem -launch system preferencies and click the icon network icon you should see qualcomn cdma...add the following settings
ppp service provider=tata
account name=internet
password=internet
telephone no=#777
modem=modem au cdma 1x winw01k
vendor=au by kddi
model=wxxx[pc card]
enable error connetcion
Jan 19, 2009 | Apple MacBook Pro Laptop Computer with...
Modem Drivers for chinese mobile phone MT 6227 and Mt6228
You can download your modem driver from here
http://www.filebuzz.com/findsoftware/Download_Mt6228_Modem_Driver/1.html
May 18, 2008 | Cell Phones
Internet promplems
for dial up simply a modem .... on laptops if you do not have a builtin modem you can purchase a pc-card modem that goes into your pcmcia slot ... for highspeed either a ethernet (same option as modem) but almost all modern laptops have a built in ethernet ... or usb ... also I highly recommend a router if you are going highspeed ... even if you only have one computer ... a router will protect your system because it provides a NAT firewall. If you go with a router make sure to set up the internet connection on the router do not tunnel through the router with a PPPoE connection
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
