Question about Canon PIXMA IP5200 InkJet Photo Printer
Printer jams. gray foam released in paper path.
I have a Canon Pixma iP5200 bubble jet printer - about 18 mos. old. Last night I was printing on plain paper and a piece of gray foam (~8"X 1/2" wide w/"fingers) released in the paper path of the printer wrapping itself around the front rollers. This caused a serious paper jam - ink all over. I carefully removed the foam from the roller (it separated into 3 pieces) and cleaned the rollers. Thereafter, the printer would try to print but each piece of paper would jam. Checked paper path again & could find nothing to cause jam. Nearest service center is 150 mi. away. Do I need a replacement for whatever this piece of foam is? Please advise best repair procedure. Thank you.
T. Ray
  • tray1341 Dec 19, 2008
    Thank you . I wondered if it really needed the foam blotter. Will try this solution this evening.
    T. Ray.
  • 679 Answers
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Posted on Dec 19, 2008
  • George Bill
    George Bill Dec 19, 2008
    Plese don't forget to rate my answer, it's how we get paid, thanks and glad I could help
Code 6A00 is comming up whenever I try to print. kindly advise me how to solve
Hello and Welcome to FixYa!
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon PIXMA iP6700D InkJet Photo Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
May 10, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Printer was working O/K last time I used it, turned it today and it tells me that there is a printer error and shows code A600. Have tried turning off and on as suggested and this has not worked. please...
Hello and Welcome
I am Angel Bird and i will be assisting you regarding the issue
The A600 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,It usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.The purge unit,called a spittoon assembly in an Canon, HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing,That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow, Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
Canon Pixma MP610 would still be under Canon warranty, get it into a shop and save yourself the hassel.
If you didn't get it and have confusion to solve it yourself then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
I hope this solution was helpful for you. Please Rate my solution it if it helps you.
Thanks & keep usin FixYa
Mar 13, 2011 | Canon PIXMA MP610 InkJet Printer
Error 6A00 on the Canon Pixma MP970
Hello and Welcome
Canon Pixma MP970 would still be under Canon warranty, get it into a shop and save yourself the hassel.
I hope it will be surely helpful for you. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Please rate my solution as Four Thumbs given below to this solution if it was helpful.
Mar 12, 2011 | Canon PIXMA MP970 InkJet Printer
Cannon Pixma Printer IP6600D Fault 6A00
Hello thanks for using fixya.
Canon Pixma iP4500 InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
See my this "Solution" same as your's & 7 people thought that it was helpful for them
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 11, 2011 | Office Equipment & Supplies
Service error 6A00
See my this "Solution" same as your's & 3 people thought that it was helpful for them
Jan 14, 2011 | Canon Pixma iP4500 InkJet Printer
I got error 6A00. model mp830
Hello i hope u 'll be fine.... thanks for using fixya.
Canon PIXMA MP830 All-In-One InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Why is the orange light on my Canon IP5200 printer keep flashing?
make sure all the catridges are proper and there is no paper jam inside in the printer.
Jan 14, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Paper comes out torn and see loose piece of foam
OK
Remove the ink cartridges and print-head then remove the long skinny piece of foam and wash it and dry it - don't wring it out but press it between sheets of paper towel. You'll see lots of ink come out of it.
Using more paper towel, clean out all the ink you can find inside the printer - there will be lots. Look at the end where the print-head parks and you'll see 2 more sponge pieces. Don't remove them but use plenty of towel to absorb as much ink as you can from them.
Once you think everything is clean look for any loose bits of paper inside and remove them. Then, refit the now dry piece of foam. It's not as hard as it looks as the thing is shaped so that it will only fit in one way. Make sure it is properly seated then refit the print head and the carts and switch on.
I've had this happen twice in the last year on my ip5200 - particularly when using scrap paper.
Dec 31, 2009 | Canon PIXMA™ MP510 All-In-One InkJet...
Printer won't print
Dear amcnabb,
How many times it's blinking? If it related to paper jam problem means there is problem with sheet feeder unit or paper sensor. Please check below link for detail.
Regards,
Source:
Canon Inkjet Printer Forum
Oct 24, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
299 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
