When switched ON, my Compaq Presario Desktop PC, a very bright and sharp blue line appears on the screen of monitor for few seconds and then goes of. Further no display. CPU led are ok. bip sounds normal. Pl. suggest what to do?
  • 111 Answers
Sounds like the power invertor in the monitor try another monitor if the prob. is still there try a new vid card
Posted on Dec 19, 2008
  • 46 Answers
Sounds like a new monitor is in order or try another one and adjust the display settings in case the monitor cant handle what you have it set at, but i suspect its a new monitor
HP Compaq Presario turns on monitor stays blank
Yes it could especially when it does not work on another monitor.
Try another video card.
Sep 22, 2012 | HP Compaq Presario PC Desktop
Compaq monitor auto adjusting
Press the button labeled "Auto" on the front of your Compaq monitor. This runs an automatic configuration utility designed to examine your current settings and adjust them to reach the best possible picture quality.
This utility will take only a few seconds and will adjust things like the sharpness, brightness and resolution of the image being displayed. Press the "Menu" button on the front of your Compaq monitor to adjust your monitor's screen settings manually in the event that the auto configuration utility has not done so to your liking.
Navigate to the "Picture" category of your Compaq monitor's on-screen menu to adjust settings like "Brightness" and "Sharpness." These settings can be useful if your monitor is displaying an image that is fuzzy or too dim.
Use the "Color" setting to adjust the amount of red, green and blue that your monitor displays. These settings can be useful if your monitor is displaying too much of one color or not enough of another.
Use the "Default" menu option to reset your Compaq monitor to its original factory settings. This changes any settings you have altered back to the way they were set when the monitor left the Compaq factory
hope this helps
Sep 05, 2012 | Compaq Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
When XP Media Center starts installation, computer freezes
Leave the CD in and restart and see if that completes the install.
Feb 18, 2009 | HP Compaq Presario Media Center SR1750NX...
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Black screen when i turn on computer.
Do a power drain :- Disconnect every cord from the back of computer tower while the pc is oiff and then press and hold down the power supply button in front of the tower..
have u tried updating the bios any time before?
Secondly,is it possible to go to the safe mode or the screen goes blank even before that?
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Monitor menu
that's a control issue with the monitor...you may need to get and reinstall the video drivers for that one...check this link, follow hp icon to model number, for computer, and look for video drivers.
Mar 16, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Screen
Sounds like the monitor is going bad. I had this happen too and had to replace the monitor and it's been great since! If you can work fine, it's not the computer itself, it's the monitor.
Dec 28, 2007 | Compaq Presario 5000 PC Desktop
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
