Question about Lexmark Office Equipment & Supplies
Cannot get lexmark 1480 to connect with wifi to computer
  • 679 Answers
I have a lexmark 4 in 1, and you need the disk to set it up, it requires the encryption key to be added in order to function, the easiest way is to hook it up wired first, then sert it up using the disk, it will tell you when to remove the wire from the router, and it will set itself up at that point. Mine works from all my machines and my iphone, if you don't have a router, you need to pick one up, I assum you do have one, good luck, and happy holiday, Gym
Posted on Dec 19, 2008
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
My lexmark 5650 wont connect to my computer
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 25, 2012 | Lexmark X5650 AllInOne InkJet Printer
Lexmark 2600
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
Jan 11, 2012 | Lexmark Office Equipment & Supplies
Lexmark printing problems
  4. Reboot computer.
Dec 29, 2011 | Lexmark Z2300 InkJet Printer
Why isn't it scanning a document to my laptop
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
My lexmark x1270 has power,but will not print from the pc
  4. Reboot computer.
Oct 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Hi lexmark. we have basic lexmark printr/scannr -- model# 4690 --- The desktop pc which initially took the lexmark CD for config. is currently off site being repaired. OUR QUESTION IS.., well,we are ...
You will have to install the printer driver software on the other computer.
During install it should ask if the printer is a network printer or direct conncected -- click network connection.
You should be able to download the software package at Lexmark's website.
Jan 10, 2011 | Lexmark X4650 InkJet Printer
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
