In WORD documents, I want to prevent accidental CAPS key engagement by requiring the CAPS key to be pressed twice to engage it or some other solution to make it more difficult to accidentally engage CAPS key in Word.
  • petelx Dec 19, 2008
    many thanks. Unfortunately none of the links worked so I think this may be an old site. No reference to Windows Vista, for example. But i did get some useful tips from the text. Thanks again.
  • kiran_g4e
    kiran_g4e May 11, 2010
    oops...i can't get u..explain a little bit clear
    Problem Solver:
  • 7 Answers
Petelx,
several possible fixes are listed HERE - without liability !http://www.bleepingcomputer.com/forums/lofiversion/index.php/t14629.html
Remember to back up Registry first
better-swiss
Posted on Dec 19, 2008
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
CAP LIGHT DOES NOT COME ON
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
I put the ignition key in and car would not start. I put gear selector in Neutral (mistake) to see if it would start in that gear. Now I cannot start the car, remove the key nor put the gear selector in...
Since today's cars have an electric solenoid the prevents accidental shifter selection, you may want to make sure that you have at least enough voltage at your battery and at the same time of engagement apply the brake pedal in order to shift back to park position.
If your battery is too weak, it may require you to get a battery jump from another person.
Jul 05, 2011 | 2002 Ford Explorer
When i push my clutch pedal down the starter engages, what is the cause of this?
Hi!!
The clutch switch is designed to prevent vehicle from accidentally engage the starter unless the clutch pedal is depressed. (It is the equivalent to the Neutral Safety Switch for automatic transmissions.)
Pressing the clutch pedal by itself will NOT activate the starter unless the key is in the RUN position.
Check your ignition switch. it may be stuck on RUN.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | 1993 Ford Escort 4 Door
My @ button is mixed up with 2 please help me solve this
Hold the SHIFT key down, and press the '2' key, to get the '@'.
Or, make sure that the CAPS LOCK is _not_ engaged.
Or, hold down the 'ALT GRA' key, and press the '2' key, then release that "held" key.
Apr 07, 2010 | Computers & Internet
I can't get the fn button to disable. when i use the keys on the right side of the keyboard, i get numbers unless i use the fn key. i thougth it was a toggle key
It appears the number lock has been engaged.
Press the Fn key plus one of the keys that has NumLk labeled on a key at the top RHS of the keyboard. This will toggle the number lock on and off, also there will be a LED light that shows when the number lock has been engage, just like when you engage the Caps Lock.
Sep 17, 2009 | ASUS Computers & Internet
Engaging CAPS Key in Word
delete this following key
Start > Run > Regedit
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Word\Data
Dec 19, 2008 | Microsoft Word for PC
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
