Question about Nintendo DS Lite Console
DS Lite repair worked, but only until I put it back together
I had to replace the bottom screen of my DS lite, which I did without any issue, but now when I put it all back together the power light comes on, the top screen flickers white and everything crashes. If I dont put it all together, the bottom screen is dangling slightly from the board, then it will come on and stay on. The back of my new screen is insulated with electrical tape, I have no idea what could be happening once I seat the board into place to be causing this issue.
  • 1 more comment
  • jason_sarnow Dec 19, 2008
    Thanks for the response,
    I have seated the board while it is on and it immediately crashes as if the back of my screen is not insulated.
    My ribbon cables are inserted correctly and I can assemble the piece fine, the tape is thinner than the backing of the original screen so I don't believe this is the problem.
  • jason_sarnow Dec 20, 2008
    It will turn on if the screens are seated, but as soon as the board is seated on top of it it crashes. Its exactly as if I am shorting the board, but I believe it to be succesfully insulated. I am afraid that perhaps a ribbon is torn and that when flexed a certain way that causes the DS to crash, but I cannot think of anyway to test this. Is it possible that the ribbon is shorting the board?
    Thanks for your help
  • jason_sarnow Dec 24, 2008
    I got a new screen and put it in, now I can put it all together and it works, however I have a new issue.
    I bought this DS from someone because it was broken, the bottom screen was all messed up. When I put it back together I went to adjust VR2 to fine tune the bottom LCD, and thats when I saw that the potentiometer was broken. I have no way of fine tuning the thing and its very flickery. When I asked my brother, whom I bought this from, about it he said that he tried to take it apart and that must be when he broke it.
    sigh
    So new question, where can I buy a replacement VR2, and if I cannot can someone please point me to a circuit diagram or tell me the specs of that potentiometer. Thanks for all the help.
    Problem Solver:
  • 12 Answers
You may have some pressure somewhere that it shouldn't be. The electrical tape takes up space, and could be taking space that is not there when the console is assembled. Or you keep knocking a connection loose when you put it together.
Try it while it's on. If the console crashes or dies at any point, whatever step you were in the middle of is probably causing that problem. Just make sure not to get anything in it while you were, and don't touch any electrical parts, in case you accidentally short something.
Posted on Dec 19, 2008
  • DeathChain01 Dec 20, 2008
    It crashes when you seat the main circuit board? Or when you seat the touch screen?
  • DeathChain01 Dec 21, 2008
    The only reason i can think of for this to be happening is a damaged flex cable (the brown flat cable running from the screens to the main board). if you happen to have a 2nd DS with you that you know works, then take the touch screen from that one, and try putting it in your DS and seat it.
    Or, the smaller cable that runs from the touch screen to the top of the main board and connects underneath the wireless adapter, that cable could be poorly secured at its main board connection point. So when you move the screen into position, the cable gets moved out of place, and crashes the system. watch to see if it is moved at all when positioning the screen.
    And as a third option, on the big cable coming from the touch screen, the one that runs off to the left, there are two open solder points facing down. These could potentially touch something if they are pressed against it, and short out whatever they are touching. Using my broken DS as a model, these solder points will touch some circuits if pressed down. Make sure they aren't.
    As my final possible diagnosis, the clip where the cables (either one) could be damaged, and are not connecting where they need to be when the touch screen is moved a certain way. The certain way is when the screen is in place. The base of the connector may be in the right spot when the screen is out, but when moved back in, the force from the wire may move it just ever so slightly out of place. Try holding the connector down when moving the screen.
    That's all I've got for now.
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
Tip
DS Lite Top Screen Replacement
Has your top screen devlouped a fault or stopped working altogether? Here is my guide to re-connecting a new top screen and fitting a new one.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen. (If you need help taking the DS lite apart then check out my other tips and tricks posted on here).
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together, after this you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Screw the DS lite back together and hope fully this has resolved the issue.
Regards,
SOD69
Feb 07, 2010 | Nintendo DS Lite Console
Changed bottom screen tested before putting back
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Nov 19, 2009 | Nintendo DS Lite Console
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
Ds lite recasing
When you take off the bottom case, and lift up the pcboard and lower touch screen, you'll see the ribbon cable connected there. It's held in place by a black connector that lifts up. Use something like your fingernail and life up on the black part until it releases (it shouldn't take too much pressure to lift it up. Once you do that, the cable pulls directly down and out.
Make SURE what when you put it all back together that you make sure to seat the ribbon cable back in there as far up as it will go. If you put it together and all you get is a bottom screen that flashes and it won't stay charging, I'm 99% sure that it'll be that connection isn't in there far enough.
I had to troubleshoot 2 of mine doing that recently. Found out that it was the cable that wasn't in there far enough. Once I put it in far enough, they worked like charms.
Oct 16, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
NIntedno DS lite bottom screen
IMPORTANT: it is not a grave or expensive problem but to solve this problem you need to dissasemble the intendo DS lite, so you must get some guidance like youtube videos on how to dissasemble the NDS Lite or other webpages with info on dissasembling the unit.
You have to carefully open the console, then check for unplugged flex cables and reinstall cables in the connectors to be sure. Then put the console together without screws to retest the unit and see if the screen is working now.
If not then you need a replacement bottom screen and depending on your abilities to retire the touch pad without cracking it you might or might not need a touch pad.
Take out the battery and charger to avoid short circuits while working.
Good Luck...
Apr 07, 2008 | Nintendo DS Lite Console
Nintendo DS lite - dropped
Might be worth taking it into a phone repair shop to see if they can replace the LCD screen. (yes, a phone repair shop - a lot of them do portable console screens too!) If they can't do it, it's probably unfixable realistically.
Mar 27, 2008 | Nintendo DS Lite Console
Ds not lite
Replace the connector cord between two screens. You can buy new ones from DX Deal extreme! Carefully remove through hinge and attach securely.
Be careful not to break the fine wires connecting. Have to twist the connector cord in the correct way to make it go through hinge without damaging.
Good luck cos it is a fiddly job.
Aug 23, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
1,209 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
