Question about Solis Master 5000 Espresso Machine
Grinder not working on my solis master 5000
Hi!
My grinder stopped functioning on my solis master 5000. I live in Montreal, Canada. Do you know where I can get it repaired within my city?
thanks,
Andrew from Montreal
  • moms99miata Mar 08, 2009
    The grinder in my Solis Master 5000 is not working. We took it apart and found a piece of plastic that jammed and stripped the grinder. I need to find a replacement grinder part for my Solis Master 5000. Anyone know where I can order the part?
    Problem Solver:
  • 11 Answers
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
Good luck and Best wishes
Lane
Posted on Jan 04, 2009
Why won't my solis 5000 grinder turn to produce a finer grind coffee?
Have to turn it while it is grinding. Don't force it or it will break.
Jun 04, 2014 | Solis Master 5000 Espresso Machine
I have got a master 5000 and the brew unit gets jammedor locks when goes on brew mode.
Hi
There are a couple (3) of things that can cause this.
1. You have a broken brew drive but you would hear a clicking noise if this happens.
2. You have an over charge going into you brew unit. There is a small knob in your bean hopper. Turn it back 1 mark and try again.
3. Your grinder has come apart and is grinding very coarse. (French press size) New grinder.
Jun 01, 2011 | Solis Master 5000 Espresso Machine
Hello, how many fuse on solis master 5000, and where are they my coffee maker has stopped running and there is no reaction on. I am repairer, y see only one fuse "F1" when this coffee maker...
On some machines, there is a fuse on the side of the boiler, under a clamp. Some newer boilers have a thermostat with a reset button on the back of the boiler with 2 black wires on it. The reset button is between the wires. There is also a power filter under the grinder side that has 5 wires on it. That can keep the machine from turning on.
Oct 29, 2010 | Solis Master 5000 Espresso Machine
Bean and water fault(red) light blinking when i turn on solis master 5000 coffee machine. how to fix it. Regards vh
HI First make sure everything is in and locked (brew unit, drip tray, and dredge drawer). Open the knob on the right and flow water through the wand. Now turn the knob in the bean hopper to 16 and push the brew button. If that didn't work you might have a clog in the grinder, and will need to clean it.
Jan 26, 2010 | Solis Master 5000 Espresso Machine
The grinder on my solis digital master 5000 winds but does not grind.
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jun 14, 2009 | Solis Master 5000 Espresso Machine
Water flow problem
Check the coffee chute to see if its clogged. It is easier to use a small amount of white rice to clean your grinder, about a teaspoon.
Feb 22, 2009 | Solis Master 5000 Espresso Machine
My solis 5000 is making a grinding sound and I have tried to reset the machine with no succes
Sometimes the grinder has grounds "jamed" in the coffee grinder outlet. First, while grinding try turning the "quantity dial" (has + and - on dial inside coffee bean holder) back and forth to see if that breaks the coffee loose. Next, Use a small brush to clean the coffee grounds channel inside the machine. To do this, remove the brewing section, liquid tray, and spend grounds holder. On upper portion of machine, just above the area where the brewing unit is a small "trap door" where coffee grounds are delivered to the brewing unit. slip the "trap door" open (it's spring loaded so you will need to hold it open) and with a small brush gently brush the accumulated grounds out of the channel. (There may be a large accumulation of grounds if you are using dark roasted "oily" coffee. Good luck! hope this works for you
Jan 05, 2009 | Solis Master 5000 Espresso Machine
Service solis master pro
Hi
Contact Quality Coffee Systems in Burnaby, BC qcs@telus.net
Dec 18, 2008 | Solis Master Top 517
Solis 5000 coffee maker
You may have sprung a leak in your machine that shorted out the electronics , that burning smell is not good :(
Find an electronic type to open up the machine a take a look inside. The top cover comes off without to much pain.
Good Luck,
Lane
Nov 09, 2008 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Apr 21, 2007 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine Logo
296 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
