Question about Sanyo DWM-2500 System
Rear left,center,and rearfront,tested these and test ok, but???
No sound on above speakers... but, woofer, front left, and rear right,are ok
  • 2 more comments
  • g_baycroft Dec 19, 2008
    at one time all worked well but recently losing sound of music
    sound mode and swapping speakers which worked well any other suggestions from experts
    any other suggetions???
  • g_baycroft Dec 21, 2008
    After all the answersI have recieved I have located the problem myself by checking my remote more closely and in one area I read the answer and it stated "surround sound" and so I tried that and bingoI had all speakers working but thanks to all the gurus for there help !!!Gene Baycroft Password f4762
  • 275 Answers
Try swaping cables from speakers, see if the outcome is different, might be a cable problem
Posted on Dec 19, 2008
  • 10,594 Answers
Get repair manual from any on-line manual store and perform Cold-Reset function in this unit. Repair manual has info how to do.
Digital Sound Processor in this unit have glitch some where in its firmware and needs Cold Reset to clear any blockage/ glitch in data stream for surround signal processing.
I hope problem will resolve because if it has any hardware failure, unit will not power up nor playback.
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
have checked to make sure that you have full surround sound turn on and it wasn't accidentally turned off. one of the thigns you can try is take the speakers that aren't worked where you have them connected and hook them up in the porsts tha you know are working. this procedure will tell you if it comes down to a problem with the speakers or if it is the stereo.
let me know what happens so i can help you further.
your satisfaction is my policy
happy holidays
Tom
  • 679 Answers
Also check the connector it may be broken or corroded, but you got two answers that are right on the money
    Genius:
  • 1,199 Answers
This sounds like you may need to replace amp at this point!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, would venture strong possibility of defective amplifier tothe front right, center and rear left are defective.
To confirm, you could actually swap the speaker wires at the rear or better still use a continuity tester to check the speakers/wires. With the continuity tester, each speaker should read no less than 4 ohms each.
Additionally, would not suspect any sound processing nor th source as possibly faulty.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 22, 2008
    Congratulations and glad you were able to sort your concerns. Merry Christmas.
  • Louie  Role
    Incidentally, appreciate sharing the information.
  • Sanyo Master
  • 19,396 Answers
Check that the speakers wiring are correct, refer to the user manual diagrams to verify.
Try swapping the Speakers connections to test if the single speakers are working.
Ensure that sound mode is set to 5.1 or to the desired output, if this is 2.1 for example, you will get only three speakers working.
If the problem is none of the above, than the unit may be defective.
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
No sound out of Front Left/Right Speakers on 5:1 setup
i have the same problem with my sony receiver. seems like the fronts and sub have no output after sitting idle for about one and a half years. center and rears are ok. any help folks?
Feb 08, 2009 | Pioneer VSX-05
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Sanyo DWM-2500 System Logo
46 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
