Question about Toshiba Satellite A135 Notebook
Issue with a Satellite P105: Battery is fully charged (new Charger), when power button is pressed, the power led flashes one time then nothing. I changed the PB sensor board, the mother board and cpu and still have the same problem. This problem occurs with or without the battery in the laptop.
  • symplee511 Dec 25, 2008
    I changed that twice with both a new and used power board, to no avail.
    Scholar:
  • 141 Answers
Whats about the power board?
cheers
Posted on Dec 25, 2008
  • wings_it
    wings_it Dec 26, 2008
    It seems that you spend already a lot of time on this Laptop. Is it really worth?
    Unplug the hard drive, RAM, Wireless, DVD player, screen, keypad, mousepad,
    When you try to start like that you should ear the alarm.
    YES, good sign, it’s working so far
    No, Try to measure the power coming out from the power board, with and without power cord.
    YES, then:
    Try to measure if you get some power on the motherboard (condensator are easy), but be carefully, NOT DIRECTLY ON THE CPU follow the wiring to be sure.
    If it seems powered, then plug one element at a time and start, you might find the element ho short cut the mother board
    First Keypad, RAM, mouse pad, screen, DVD , and wireless
    Good luck
Green light on new Ryobi charger flashing when trying to charge battery it that normal
Yes, the green light flashes until the battery is fully charged on Ryobi chargers. This will change to a solid green light when the battery is fully charged until the charger goes to a power-saving mode. Not all of the Ryobi chargers have a power-saving mode. However, for those that do, the green led will dim over time and then brighten and dim slowly again in this mode.
My Ryobi charger, model P113, actually has a key for the LEDs on the unit on the left of the battery port. The manual for this charger is here: https://manuals.ttigroupna.com/system/files/5495/original/P113_192_trilingual.pdf?2011 . Ryobi has many of their manuals on their site. Look up your charger/tool here: https://www.ryobitools.com/power-tools/support/manuals , Home Depot's web site also has many of these manuals on the product site for the tools that they sell.
I hope this helps.
Mar 13, 2017 | Ryobi Drills
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
My laptop wont charge of swith on toshiba laptop brand new
If you have another power charger try it. It can only be one of two things. Bad charger or bad battery. Most likely the battery will need replaced
Aug 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Toshiba P105-S6004 Laptop will not charge battery
Motherboard repairs are often poorly done and they are expensive except for the simplest jobs like replacing the DC jack. And new motherboards are also generally very expensive. And cheap way out of this is buying a used battery charger or a used working motherboard. eBay is usually the best place to start. Good luck!
Jan 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Toshiba Satellite A135 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
