Question about RCA P52937 52" Rear Projection Television
RCA 52" REAR PROJECTION P52937 FRONT BUTTONS WILL NOT WORK
My buttons just quit working along with the remote to turn off and on i unplug and volume button turns it on please help can i change the board the buttons are on and if so how hard is it.
  • RCA Master
  • 5,138 Answers
It just plugs in and try cleaning contact switches first with contact cleaner see if this fixes it.
Posted on Dec 19, 2008
The only control on the front of the tv that works is the on-off button. When the tv is turned on it continuously changes channels as if someone is holding down the up channel button on the remote.
I know the set well and would like to help---FIRST THING IS DISCONNECT THE POWER TO THE SET---a few minutes will be enough.
Plug set back and a good chance it will have returned to normal
If not let me know and let me know if on the front of the cabinet it has the "GUIDE PLUS" LOGO.
Dec 06, 2012 | RCA P52937 52" Rear Projection Television
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Where is the eye for the remote on the TV????
Hi, remote sensor is located behind the front screen, if the remote doesn`t work as well (you didn`t say so I`m assuming it doesn`t) then you either have bad tact switches on the control board (the buttons on the front of the set) or the 5 volt line to the control board is missing, video-tek
Feb 03, 2009 | RCA P52937 52" Rear Projection Television
Front panel
Either replace front panel board or all contact switches on that board the one with vol- vol+ ch- ch+ power, menu.
Dec 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 Inch
First off unplug for at least an hour. If this doesn't help, then you are in component failure. You will need to supply model,chassis and manu date for good help and you will need local expert to repair.
www.classtorations.com
Jun 08, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Apr 13, 2008 | RCA P52937 52" Rear Projection Television
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
Scrolling
Sounds like it has one of two problems first one could be a stuck button. The micro locks up and the set wont come on also could be causing the channel scrolling run you finger along the channel buttons. Other than that you would need a new signal board you have a locked up micro...this part will be No longer Available.
Bad power botton,volume,channel,and menu botton
The buttons in front panel of the tv are bad,part number for these are 268854
Dec 16, 2007 | RCA P52937 52" Rear Projection Television
Scrolling
the buttons in the front control panel are bad,these switches part number are 268854
Dec 12, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
