Question about NewCon Optik BN 5 (2.5x62) Binocular
Newcon BN5 bipppppppppp
Hello, i have a new newcon bn5, when i turn it on it makes a noise "biiiiiiiiippppppppp" and shuts down in 1/2 seconds when i release the button. we have to leave the finger in the button, unless it shuts down immediately thank you denys
  • 944 Answers
Try contacting these guys, i cant find any online info about this fault, it sounds like a serious problem in the circuitry that can be fixed - the biiiippp is an error message and the shutdown should protect from further damage; http://www.newcon-optik.com/contact_us.html Hope this helps :)
Posted on Apr 11, 2007
SOURCE:
Projector shuts down every 30 seconds. is this a bulb issue or other internal issue?
it can be one of two things
1 The Bulb need to be replaced, (do not buy from Sony, buy it from amazon for about 70.00
2 check your filter make sure you are getting enough ventilation.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jun 16, 2012 | Sony VPL PX30 Multimedia Projector
I have a newcon-optik stargate that will only come on about 1 second after I press the lever. It only worked about a week after I bought it although I can't send it for repair under warranty right away...
Hello, it could a bad switch. Have you tryed hold down on the switch and see that works. If so, then the switch is faulty. You know that this NewCon Optik CON STARGATE-M is Russian manufactured by Optik one of the six or seven Russian companies manufacturing these NV devises. GB...stewbison
Aug 31, 2011 | NewCon Optik CON STARGATE-M
When i on my tv after a few seconds it shut downs automatically and on after a few second makes a loud noise help.............
Hello, it sounds like a problem with the switch mode power supply. Theres a good rule to go by, any noise,switch it off and leave it that way. You need to get a technician to look at it.
Mar 23, 2011 | Televison & Video
When I turn my HP Pavillion on, it makes 1 long 15 second beep then about 5-10 seconds of silence then another 15 second long beep. It does this continuously. There is nothing coming up on screen at...
If not solved yet, make sure the fan is spinning on the heat sink on the processor. If it is, then if you have a video card installed, make sure that fan is spinning. These are 2 pieces of hardware that will cause the beeping and shut down.
Dec 13, 2010 | HP PAVILION A6230N DESKTOP PC
Noise after engine turns off
It might be just the radiator fan cooling excess heat.. mine does it sometimes on hot sunny days
May 03, 2017 | 2005 Mitsubishi Outlander
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Dec 26, 2008 | Maytag MTB1891AR Top Freezer Refrigerator
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
Newcon Optik Night Vision Binoculars BN5
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
Nov 06, 2008 | NewCon Optik BN-5 Binocular
NewCon Optik BN 5 (2.5x62) Binocular Logo
219 people viewed this question
Top NewCon Optik Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
ray gallant
Are you a NewCon Optik Optic Expert? Answer questions, earn points and help others
