COMPUTER WON'T WORK WITH NEW HD LCD TV
JUST BOUGHT A NEW 26" HD LCD TV. TV WORKS FINE. WHEN I START MY COMPUTER I SEE THE WINDOWS LOGO (XP) WITH THE TOOL BAR LOADING FOR ABOUT 7 SECONDS. THEN THE SCREEN GOES BLUE WITH A MESSAGE OF VGA NOT SUPPORTED. ANY IDEA'S? THANKS
  • 4anyparts Dec 20, 2008
    Thanks for the info. As it turned out I had to download new drivers for the geforce 6200. Nvidia pretty much walked me through the process to download as well as clear out the old version. Once it was done, rebooted and everything worked. Thanks again, you were on the right track.
    Problem Solver:
  • 13 Answers
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Posted on Dec 20, 2008
  • lineswine Dec 20, 2008
    By the way, typing in all caps = shouting.
We bought samsung LCD 26 inch last july,in august 2010 suddenly our LCD off,engineers said your panel and Ip circuit is not working..so only option is left buy new one or repair the LCD.What should we do?.
Check the cost of repair estimate. If you have covered under General Insurance policy try to get the claim.
Ask the Engineer to identify the fault. Both LCD panel and drive electronics can not fail together. If so it must be a lightning strike!
Check the estimate value and decide. After repairs insist for warranty.
Sep 08, 2010 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Envision L19W761 LCD TV - VGA mode failure.
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Jun 26, 2009 | Envision L19W761 19 in. LCD TV
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Tv won,t turn on
1-877-778-8876
Call for a service call
Jul 09, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Computer shut off
you have a hardware conflict or a bad power supply/MB. or a bad video card/driver. or a bad RAM chip. uninstall everything but one chip, one HDD and CDROM, and one video card. install the OS rom there... then add items until it becomes unstable. the last thing you installed is the bad boy.
May 22, 2008 | Samsung DLP HL-P5663W 56" TV
Speakers maybe...
Re: Protron LCD tv - READ THIS #631 I work for Protron.
We are in a big dispute with the Chinese factory that makes Protron LCDs. No replacement parts will be coming, ever.
There are no remotes and no power supplies available.
PROTON has already won their lawsuit which prevents us from selling under the name PROTRON. As soon as they pay the bond, we are shut down.
Our management is in chaos. Our customer service dept is non-existant. Our rating with the BBB is 'F'. The product is cheap because it is made with cheap parts. Getting the picture here?
If you buy a Protron LCD, you are completely on your own.
Good luck.
Oct 21, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Computers & Internet Logo
590 people viewed this question
David Payne
David Payne
