Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Z60 [blur]
My casio Z60 got wet because I threw my bathing suit on it and I didn't know it was under it. Now all I can do is look at my pictures already taken but only for a few seconds. When I turn it on, it shuts off in about 5-10 seconds and the picture in the screen is blurry. I can't take a picture and I just wanted to know what I should do. Thank you. Alexis
  • 374 Answers
If the camera even got a little bit wet I would recommend that you send it in and have Casio take a look at it. Water, sand and even the slightest drop damages these cameras like you wouldn't believe. Call the repairs center at 800-706-2534 and then keep choosing option 1.
Posted on Jul 08, 2007
SOURCE:
Casio Exilim EX-Z60 6MP lines
No, it is not caused by settings. Probably CCD sensor is bad. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blurred photos
if you are shooting in manual mode or with aperture or shutter priority, be sure your shutter speed is fast enough to avoid blur. hand-held shots are typically safe at 1/250 or faster.
Apr 21, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
CASIO Z60
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jan 15, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blurred pictures
If it's from moisture then once that dries out it will clear up. Otherwise if it doesn't then you will have to send it into repairs and they can clean the internal lens for you.
Jul 31, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Lens wont retract on my exilm zoom ex-z60
If it is under warranty Casio can fix it for free. other wise you end up paying the labor/parts. Can become very costly. I suggest open the case and replace the plastic housing that hosts the saw wheels. Should fix the problem
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60 problem with not being able to get the LCD working after dis-connection and re-connecting the connectors
The LCD will not show the picture until you put the ribbon all the way inside the connector
Hope this helps
Joe
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
EX-Z60
Yes, the rear LCD cover is part of the case. The case can be removed and replaced.
Sep 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Help
Do the pictures have lines across them as well as being blurry? If you see the lines then your shutter is stuck open and it will require repair. The shutter has to close for the image sensor to properly record the image. If they have no abnormal lines on them, are they "out of focus" blurry or is it more of a streaked motion blur kind of thing? If you do need to get the camera repaired you should check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Feb 27, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
136 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
