Question about Emerson MS3108 Shelf System
The rubbing Emerson CD player
This is one of those that a door opens and you place the three CDs on the deck one beside the other.
After puzzling through your answer, I realized you were talking about the shove em into the slot type.
Seems like since the seating is faulty some sort of alignment of the piece onto which the CD sits may be required
Here is my original note for your convenience. Many thanks and Merry Christmas/Happy Holidays! Dave
I have an Emerson model ms3108. The third of three cd disc players does not allow the cd to seat properly. So extreme is the problem that you can hear the cd rubbing, and it goes slowly. It seems to be rubbing at the top of the disc, and there is a noticeable gap at the bottom. This is consistent. The second cd disc player also has the problem, but less severe and does play the cd with a little persuasion. The machine's door also opens very often. My guess was that was due to the improper cd seating. Is there anything I can do about this situation?
    Novelist:
  • 152 Answers
Hello, is this a carosel type loader? they have other internal parts that rotate it for selecting cd,s i understand what you mean.
the reason i say to open the case is incase there is something obstruction the mechanism from going in to the right return position
if you allready checked for this and theres nothing blocking the return cd holding part. then you may need to check this cage assembly for internal broken loose screws or jammed parts.
some plastic parts sometimes break or wear out and cuase the return cage to not load the cds properly. this is a loader issue
your on the right track, it is something with the returning cage
also at times the rubber shock resistant booties on the cd reader & motor assembly they are missaligned or come apart
if a cd dosent sit properly it pushes the drive motor and thats when the rubber mountings can come apart. reader assembly & motor mounts. check for this also.
good luck with your player.
happy holidays
Posted on Dec 19, 2008
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
My cd player door opens then close then stays open
The disc loading mechanism is faulty. Check the loading belt first. Replace it. If this do not help you, replace the disc loading mechanism. if you are not handy, seek tech support.
Jun 04, 2012 | Emerson MS3100 3-Disc CD Changer
When moving around electronics near my tv, i must've tilted the radio/cd player just slightly & the cds came out of their slots, & now i can't get them back in, or get it open to get my cds out..
its very easy take off top cover off cd player and you will be able to see cd and pull them out one by one and cd will player will play normal again make sure device is off and some case you may have to turn on because cd get wedge but motor on cd will help once you get other cd out to get the one that is wedge
Aug 25, 2010 | Emerson Audio Players & Recorders
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
Saying no rdy on cd player (Emerson)
make sure you have a cd and your tray spins when opened
Aug 11, 2009 | Emerson MS9700 CD Shelf System
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
RCA RS2620 - CD works well ocassionally and then not at all
Simple solution - a CD lens cleaner did the job. $11
Feb 19, 2009 | RCA RS2620 Single Cassette Deck
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
CDs get scratched when instered/ejected in the players
Sounds like something inside the deck is out of place, and is scratching the cd. Please bring your decks to an authorized service center to be checked out.
Oct 26, 2008 | Denon Dns1000 Table Top CD Player CD...
Emerson MS3108 Shelf System Logo
116 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
