Question about X-10 X10 FireCracker Remote Control
I need to do programmable micro-dimming in x-10 on a budget, anyone know how?
I want to make a dawn simulator like this one here: http://alumnus.caltech.edu/~jimmc/dawnsim.html However I would like to have the dimmer brighten in micro steps. I will be using an led circuit which is very non-linear and I will be losing a lot of gradation, so having as many dimming steps as possible would be nice (i.e. 200 instead of 20) Ideally I would use a mini timer that starts a module like the cm11a, which sends micro brightening steps to the dimmer module. If this is not possible I could leave my pc on but this is not preferable. I would also be willing to use other standards like insteon. Thanks, jjbologna
    President:
  • 3,130 Answers
Make an adjustable 555 timer circuit, not only reliable, but as been used for years!
Posted on Mar 31, 2007
SOURCE:
Orbit watering timer, has a budget option, what does that mean
Water Budgeting
Water Budgeting is a simple way to adjust your watering
duration to match seasonal watering needs . Water Budgeting
works by increasing or decreasing watering duration for all
stations in each program . Press the [PROGRAM] button to
select the program you wish to budget .
Adjustment range is from 10% to 200% by increments of 10% .
The default value is 100% . The budgeting will remain on the
adjusted range until you change it .
May 13, 2017 | Orbit Hardware & Accessories
Where can I get a dusk till dawn timer master plug did one that I wanted a TDD-MP but cannot get them anywhere so now looking for a Paget dtd timer where can k get one
  • No Paget, but lots of others
  • DUSK TILL DAWN LAMP TIMER - Nexus Industries www.nexusinds.com/masterplug/downloads/pdf/TDD.pdf · PDF file DUSK TILL DAWN LAMP TIMER SWITCHING MODES i) Timer mode ii) Random mode iii) On mode iv) Off mode v) Dusk 'Til' Dawn mode i). Timer Mode The timer will turn ...
  • Dusk to Dawn Timer ' eBay > www.ebay.com/bhp/dusk-to-dawn-timer Find great deals on eBay for Dusk to Dawn Timer in Light Timers. Shop with confidence.
  • images of dusk till dawn timer bing.com/images b3eo0&w=105&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">551o0&w=60&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">6f9o1&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">595o0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">773o0&w=107&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">fcfH0&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of dusk till dawn timer
  • Dusk to Dawn Photocell Sensor Timer Switches 10.02 www.acetek.co.uk/id66.html Acetek manufacture Dusk to till dawn photocell timer light sensitive sensor switches for energy saving lamps LED 6v 12v 24v and 240vAC
  • Dusk Till Dawn' Self-Dimming Lighting. - D-D The ... www.theaquariumsolution.com/files/Dusk Till Dawn Instructions... · PDF file 3 Step 4 - Synchronising Programme with the Plug Timer It is necessary to synchronise the Dusk till Dawn chip to the time of day during which the unit has been ...
  • Amazon.com: dusk to dawn timer www.amazon.com > Search > dusk to dawn timer Amazon.com: dusk to dawn timer. Amazon Try Prime All Go. Shop by Department. Hello. Sign in Your Account Sign in ... after 2,5 or 8 hours / Dusk to Dawn default timer
  • Items found similar to "DUSK TILL DAWN PHOTOCELL ... - eBay www.ebay.ca/sch/sis.html?_nkw=DUSK+TILL+DAWN+PHOTOCELL+SENSOR... Photocell Timer light Switch Daylight Dusk till Dawn Sensor Light switch G8. ... 5 Pcs Dusk To Dawn Photocell Light Control Auto Sensor Light socket Black.
  • Amazon.co.uk: dusk to dawn timer www.amazon.co.uk > Search > dusk to dawn timer Amazon.co.uk: dusk to dawn timer. Amazon.co.uk Try Prime All ... Battery Operated Fibre Optic Snowman, Built in dusk till dawn light sensor. Kitchen & Home: ...
  • Feb 05, 2016 | Hardware & Accessories
    I just purchased a Venture RX-7 reflector telescope at the thrift store. Got home and it's missing the eye piece lenses. Anyone know where I can order these? Any help would be appreciated! Thanks!
    With an aperture of 110 mm or so, the absolute largest useful magnification with this scope is about x 220 (certainly not 375 like thay say). However at this limit the image is dim, difficult to focus, and jumps around with any vibration. A more practical limit is about x 150 or so, which is attained with about a 4mm eyepiece.
    I'd suggest 3 EPs in the range 5 - 30 mm. Alternatively buy 2 EPS and a x 2 Barlow Lens (This is a magnification multiplier, placed between the scope and EP, to double the magnification of that EP). A 10 mm Plossl EP and a 30-32 mm will give a good spread with the 2 x Barlow.
    http://www.optcorp.com/eyepieces/all-eyepieces-not-sets-kits.html?dir=asc&e_eyepiece_barrel_size_f=678&order=price&p=1
    Even tho the scope is a budget model, a better lens will get the most out of it. . You will soon want a better one.
    Mar 31, 2015 | Optics
    When hitting the next/on/off button, it dims the lights vice turning them off???
    The EJ500 is rated for incandescent (resistive) bulbs only, and not LED CFL etc.
    Max distance between light and timer is 100 feet and wire cannot be underground.
    Replace with ST01 timer, or Ei600 timer... these timers are rated for any load (resistive or inductive), and are programmable or dawn-dusk... 7 day... single-pole or 3-way
    http://waterheatertimer.org/Programmable.html#st01
    Gene
    Water Heater Timers Save Money
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
    Nov 12, 2014 | Intermatic Inc. EJ500C Digital Wall Switch...
    I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
    U2-10 is 'SRAM user authentication check sum error'
    Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
    You will be in U code clear.
    Press 'execute' on the screen.
    The machine should reboot.
    It may start to work again.
    If not you will need to replace either SRAM chip or the main board.
    Oct 31, 2010 | Sharp Office Equipment & Supplies
    I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
    * Entering the simulation mode
    1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
    CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
    code of simulation
    2) Entering a main code with the 10-key ? START key ON
    3) Entering a sub code with the 10-key ? START key ON
    4) Select an item with the scroll key and the item key.
    5) The machine enters the mode corresponding to the selected item.
    Press START key or EXECUTE key to start the simulation opera-
    tion.
    To cancel the current simulation mode or to change the main code
    and the sub code, press the user setup key.
    * Canceling the simulation mode to return to the normal mode
    1) Press CA key.
    Sep 06, 2010 | Sharp AR-M620N Copier
    Toshiba rd-98dtkb hdd& dvd video recorder. Today I found that the date is showing 04/03/2010 instead of 01/03/2010. time is correct but when I changed the date it still goes back to 04/03/2010. anyone...
    Sorry, dont have a solution, I have the SAME problem. Today is 01/03/10 but DVD player in EPG is showing 04/03/10 and has not taped today's programms set on series link. Can anyone help?
    Mar 01, 2010 | Televison & Video
    I JUST NEED TO KNOW HOW TO SET IT TO GO ON A DUSK FOR ABOUT 4 HRS. IS THERE A CERTIAN SEQUNCE? THANK YOU
    One
    have it pluged in to a timer plug for your 4 hr shift you need it to work for ,
    Two
    you should find some ajustment screews on it that let you set it to dusk , dawn ,
    Dec 02, 2009 | Ace Hardware AMERICAN TACK 3236858...
    Naturally Speaking 10 for Windows usable on a Macbook?
    check NS website for appilcable mac options
    Jul 09, 2009 | Computers & Internet
    Purchase of workstaion/server for three diemnsion simulation
    Hey sorry for the late reply
    you dont need much surprisingly
    1 AM2(X2) DUEL CORE DUEL PROCESSOR MAIN BOARD >> i suggest msi
    2 AM2 AMD PROCESSORS abt 4.0 GHZ each
    4 GB MEMORY
    2 500 GB HARDDRIVE (SATA)
    1 DVD BURNER
    an alien case with a 650watt (or more) power supply
    enjoy
    Oct 26, 2007 | Computers & Internet
    Televison & Video Logo
    204 people viewed this question
    Top X-10 Televison & Video Experts
    Marvin
    Marvin
    Are you a X-10 Televison and Video Expert? Answer questions, earn points and help others
