Question about Samsung LN52A630 LCD TV
Refresh rate at 60 Hz?
In the little on-screen dialog at the top left of the screen, the tv shows the current display resolution followed by the refresh rate which has 60hz. Shouldn't it be at 120hz? I am viewing verizon fios through my receiver. All cables are HDMI.
Http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010100&model_name=LN52A630M1F
According to the Samsung website, the on-screen information is in relation to the incoming signal, not the TV settings which are being displayed.
As long as you have the 120 Hz turned on, the TV will display the picture at that refresh rate. However, the on-screen information will not reflect that.
Very ood.
Posted on Feb 13, 2010
I have a screen flickering problem on my hp pavilion dv4-1120us.how do I fix it?
Try to use Display options to change the refresh rate. If you're on 60 Hz, you might want to change to 71 Hz or something different from where it is currently set.
Depending upon which version of Windows you are using, you get there by right-clicking on a blank spot on the desktop, and choosing Graphics options or Screen Resolution, then looking for the setting for refresh rate.
-a.
Jun 24, 2012 | Computers & Internet
I have a compaq monitor that has a popup stating Input signal out of range. Change to 1440X900 60 Hz. How do I do that?
Your monitor does not support the display settings you have set in your operating system.
To change these settings go: (Windows 7)
Control Panel > Display > Screen resolution [Change to 1440x900]
then on the same screen, go to Advanced Settings > Monitor > Screen Refresh Rate [Set to 60 Hertz].
(This usually happened if you switched monitors, or used a TV, or maybe a projector).
You can use the same method to set up any resolution or refresh rate you want.
Sep 23, 2011 | HP Pavilion F1523 15" LCD Monitor
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
Input Not Supported
Yes, you can try reducing the refresh rate to 60 Hz.
You can change this option in Display option in control panel.In the display proreties dialog box under settings tab,click on advaced button.click on Moniter tab.there you can find screen refresh rate option,change it to 60 Hertz.
This would solve your problem.
Feb 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Trouble setting up VGA cable to watch movies from my computer on my TV?
First, make sure the VGA cable is plugged into the AV6 slot on the back of the TV.
You will have to go into your computer, and click Start --> Control Panel --> Appearances and Themes --> Display --> Settings and change the screen resolution to 800 x 600 first.
Then go into the program for your Graphics Card and change the screen resolution to 800 x 600 with a 60Hz Refresh Rate - sinc ethis will most likely be a change for you, your computer screen will seem to "flash" a bit - your eyes will adjust as you become used to this.
The other resolutions that work will be the following, but the 60 Hz refresh rate is the key:
Supported Display Resolution•Computer formats: 640 x 48060Hz, 800 x 600 60Hz, 1024 x768 60Hz, 1280 x 720 60Hz•
Feb 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Screen shift
Try setting the refresh rate to 60 Hz. (Maybe 75).
Is it xp?
Right click an empty part of the screen, properties, under monitor (I think; I'm on Vista) you can choose the refresh rate.
Most LCD's should be at 60 Hz.
Jul 04, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Out of Range
the refresh rate of your computers graphics card is set either too high, or too low. right click on the desktop, select properties, go to the settings tab, and click advanced. then go to the Monito tab, and play around with the different refresh rates, until the picture will show up. This is usually, around 60 Hz or less.
Feb 10, 2008 | Philips Magnavox 27MS343S 27" TV
Samsung LN52A630 LCD TV Logo
585 people viewed this question
Jerry Greenberg
Jerry Greenberg
