Question about Kenmore 63942 Dryer
Dryer functioning but not effective
I have a Kenmore dryer that is working but is not drying the clothes, or more correctly, takes a very long time to dry. What is likely the problem?
  • 318 Answers
First thing you need to know is that heat is not all it takes to get your clothes dry. what you need is to get the moisture from the clothes out of the dryer. the only way this happens is with air flow and that is what you are lacking.
the way to find out is make sure your lint filter is clean, then check to see how much air is going out of the house. most likely the vent is pinched off behind the unit causing very little air flow. if the vent is straight and as short as possible, then you may need to have your vent cleaned out fro the unit to outside your house.
clean or fix the vent and if you can remove the vent from the dryer, let the air go into your laundry room and try a load that way, if it works then you know the vent is the problem.
Posted on Dec 29, 2008
FRIGIDAIR DRYER model -FER641FS0
The timer is probably bad. If the dryer works on sensor dry use that. A timer is so expensive it is not cost effective to buy a nee one. You may as well buy a new dryer.
Oct 12, 2014 | Dryers
Kenmore Elite Clothes Dryer working but not drying
First take dryer vent hose off and check for a plugged vent, clean it all out. There is either a clamp on the hoses you take off by prying or with a screwdriver, should be two one at the dryer and one at the vent to exit the house, also make sure that there is nothing blocking the door on the vent that exits the house sometime animal like to build nests there. If this does not fix the problem it could be the heating element in the dryer, sometimes it is cheaper to just replace the dryer than the element
May 21, 2012 | Kenmore Dryers
Have a Kenmore HE4 Dryer and it seems all buttons and functions work, but the dryer takes multiple cycles to dry clothes - even on regular/normal settings. Is it a problem with the heating element? ...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Hello I have a Kenmore clothes dryer (80 series). It takes multiple cycles to dry the clothes.
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Oct 26, 2009 | Kenmore Dryers
Dryer takes long time to dry clothes
Remove the rear connecting vent and try a load at 45 minutes time dry. If it dries correct the vent blockage problem.
If not, let me know for step 2.
May 23, 2009 | Kenmore Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore 1 10.74842400 gas dryer series MR2906966
Check resistor on or near timer with ohmmeter. Wiring diagram
should have correct resistance number. Always unplug unit first.
Mar 23, 2008 | Kenmore 73952 Gas Dryer
Kenmore 63942 Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
