Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Loud electrical sound in rear of set(tv)
When pressing the on/off switch, the tv makes a loud welding noise ans is also spark producing and the unit has no picture of sound.the tv is only 2 years and 7 month old.
    President:
  • 3,130 Answers
Sounds like the High voltage is leaking out and arching somewhere. Have a look in the back and see where it is BUT be CAREFULL!! This is enough voltage to cause serioud harm to you. If you have no TV repair experience, this is not the repair to start experiementing with. Play it safe and call out a pro to assist you. Good Luck.
Posted on Mar 31, 2007
Makes terrible sparking noise and then shuts off
this noise is from a bad Magnetron need professional repair
Feb 01, 2014 | Danby DMW799 700 Watts Microwave Oven
My HD61LPW42 makes a high pitched wirring noise after it is on a few seconds sounds like the fan is rubbing against something but doesn't appear to be. The picture quality is still good and the tv...
this might be a noisy color wheel . this is a motorized wheel that produces the color in the set. it could be something else because of your statement of picture is ok. if it the color wheel the set will eventally shut down. this part used to be avalible and fairly easy to replace. it has got harder to locate. The other possibilites includes a small leaky capacitor in the powers supply but that is more like a whine. a tech would have to take the back off and locate the noise.. i believe this unit might have 2 fans and a color wheel. three moving motors.. anything that moves eventally dosnt
Mar 22, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Loud buzzing noise
sounds like a color wheel problem, I can send you a DIY File with pictures if you wish. Contact me at techman32K@ yahoo.com. Good Luck!!
techman
Sep 05, 2009 | Samsung HCM5525W 55" Rear Projection...
Funny noise and electrical smell
Sounds like a product defect to me, I would be on the phone with LG to get a certified tech out to the house ASAP!
Mar 03, 2009 | LG RU-52SZ51D 52" Rear Projection...
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Noisy TV (Hitachi)
The noise in question relates to capacitors, which are (unfortunately) largely dependant upon environmental elements. You most probably find that when outdoors is wet and humid, there is no issue, but the moment the sun is out and it drys out, your problem rears its ugly head again. This is a basic fault and should be able to be solved by a standard TV tech shop, as its in short, humidity dependant. To explain caps, are moisture based electric storage devices; under normal circumstances the chemicals react ideally to provide the expected volts and or current. Alter the environment subastantially and the cheaper versions will not adapt and they will put the unit 'out of spec' as a dryer environment will produce less volts/current and more humid environment will make it perform closer to spec. Its a sod of a feature but thats earth. :) Higer class ie Class 'A' components tend not to suffer dramatic changes and produce more reliable results.
To sum up, the loud humming is caused by out of spec components or for that matter dried up used up components, the fact it runs for hours at a time is most likely weather dependant and if not its likely to be a dry joint somewhere on the board. These are also unfortunately largely dependant upon environmental conditions. Best of luck. :o)
Oct 31, 2008 | Hitachi 60V500 60" Rear Projection...
RCA Rear projection Tv D52W25
the would be you high voltage flyback do not run the set while this is happening as it could do more damage.
you should replace that part.
Jan 09, 2008 | RCA P52926 52" Rear Projection Television
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
