Question about Maytag Neptune MAH5500B Front Load Washer
Replace control membrane
The washer was not used for nine months ,control membrane has to be replaced where can it purchased . fl33330
  • 157 Answers
Maytag or try ebay
Posted on Dec 19, 2008
How to Upgrade from nine pin to six pin sta-rite replacement membrane
Just use the six pins that line up with the connector and leave the other three alone, starting from the top of the board.
May 24, 2014 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Whirlpool gold oven, error message: e0 F2
Stuck keypad. Use a hot rag to clean over all buttons. If that don't work then membrane needs to be replaced. If membrane is replaced and error still occurs replace control.
May 12, 2013 | Ovens
My GE microwave has a Keypad short. Do I have to replace the entire control panel?
Depending on part availability I would recommend the replacement of the keypad "membrane often shorts" but they may offer the control board with it since it ties together.
Mar 14, 2012 | GE Microwave Ovens
I have LG 42LG30 15 months old the remote control is very slow and often has to pressed several times before it works and less often does not work at all, can you help ? The set is still under warenty.
The rubber keys are moulded as protrusions from a rubberised membrane which is slightly permeable to sweat and grease. Over time this builds up as a corrosive yellow greasy deposit on the reverse side of the membrane which prevents keys from making good contact with the circuit board behind. The process occurs far more quickly if you regularly operate the remote with greasy hands such as is the case if you regularly eat in front of the tv, or if you (or any other user) frequently use hand moisturiser.
There are only two repair options:-
1. Take apart the remote and thoroughly degrease it. The membrane itself can be washed in soapy water but dry it thoroughly before refitting. At best this is only ever a temporary fix.
2. The official fix (and best) is to replace the remote.
May 10, 2010 | LG Electronics/zenith 6710t00008 Remote...
Control panel for GE microwave
The control panel module is different from the membrane. Unfortunately these modules themselves are usually very expensive, perhaps 1/2 the cost of a new microwave.
Sorry.
Oct 06, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Tl Spin settings
I would try verify that the spin cycle membrane key is not stuck/defective signaling the controller to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test to get a start point.
Do you have the troubleshooting guide stored in the control panel? It was shipped with the machine, pull 120VAC washer power plug, remove the top three torx screws at he top back of the control panel and remove the trouble shooting guide. Rassemble and power up your machine. Follow the instructions for Membrane Pad Test. You will enter Service Mode to verify that the key pad function LED can be toggled, just press each key once except the Presoak key as described below. If you don’t have the Troubleshooting guide that came with your FAV6800A I have pasted in the test from the SM;
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin
Only keys for three seconds or until the control beeps.
Membrane Pad Test
While in Service Mode, pressing the Presoak key will
start a membrane switch check that verifies switch
operation. All the LEDs (except Presoak ) can be toggled
or slewed by pressing the key associated with the LED or
set of LEDs. Each time either set delay arrow is pressed
the digits toggle between a blank and 8. All keys
(including the OFF button) must be pressed within 5
minutes for this test to pass. “PA” will be displayed for
five (5) seconds once all keys have been pressed and the
test is completed. Following 10 seconds of inactivity at
any point, this test will exit without any display.
Let us know your results.
Dec 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
I have a Magic Chef gas range/oven/stove model #3468VTV. Fault code F1 apprears and the range continually beeps. According to the Manual it states F1: Condition: touchpad membrane defective or clock...
UNPLUG...Then you need to open the control panel and there is a ribbon cable you remove from the main control board then plug the unit back in to see if the F1 is gone if so you need to replace the Touch pad
May 28, 2008 | Magic Chef Kitchen Ranges
Neptune front load washer buttons wont work
I tried un pluging the machine for few hours and it will work for 3-4 load and then it will lock up again
Nov 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
