Question about GE JVM1850 1000 Watts Microwave Oven
Microwave GE JVM1631
I have a microwave and i can't seem to get the lights working under the bottom for the stove stop. i have checked all the electrical and there is power, i have replaced the bulbs but still no light.
  • Anonymous Mar 15, 2014
    2 bulbs to replace under the microwave that light up stove top and serve as night lights
Jvm1631
Posted on Apr 12, 2008
    President:
  • 3,130 Answers
The control board is bad. Good Luck
Posted on Mar 31, 2007
SOURCE:
GE microwave JVM1631 turn table not working. How to fix it?
The motor underneath the turntable may have failed. Removal of the access cover will expose the motor for continuity checking
Aug 17, 2013 | GE JVM1631 Microwave Oven
How do i remove the plastic cover to change the light bulb in GE Microwave
Hi, I have a ge modle jvm1631 and mine has two scerws in the front of the cover (can be hard to see in dim light) on some modles you might have to have door open and screws will go in from bottom of cover. Then there is a filter inside that you take out and remove a metal plate that covers bulb.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
The over the stove cook light button is broken.
The screws of the lid are located at the back and bottom of the oven.
Sep 08, 2017 | GE Profile Spacemaker Over-the-Range...
I have a jvm1631 and its flashing f3 code
you have to power cycle it to get rid of the Error... if under warranty... call GE for service...
they will replace the main board...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | GE JVM1631 Microwave Oven
GE Spacemaker JVM 1631: Starts working and stops 3 sec later??
your magnetron is leaking RF do not use until you replace the magnetron, it is interfering with the pc board
Feb 05, 2010 | GE JVM1631 Microwave Oven
Microwave
Replace the control board, It is bad. Good Luck
Mar 31, 2007 | GE JVM1850 1000 Watts Microwave Oven
Another microwave stopped heating
you could try http://applianceguru.com/
Mar 06, 2007 | GE JVM1631 Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
185 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
