Replaced coils and Ingit.kit yesterday
If the coils and ignition are correct, and you are 100% positive that that they are installed correctly. I would check the primary fuse, as well as the high and low limit switches and thermostat. There are instructions on the internet for testing and troubleshooting these. I had the same issue and it was a combination of a clogged vent tube (not behind the drier, but the stack to the roof and the thermostat was bad.
SOURCE: How do I replace the heating element for the Kenmore series 90 dryer?
let me know if you need help
SOURCE: My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: dryer not producing heat
Hello there:
it sounds like to me that the heating element is what needs to be replaced
I would contact a local authorized appliance repair man to get a repair quote ok?
best regards michael
SOURCE: dryer runs fine. No heat, so replaced element
there should be 2 thermostats on the element.these must also be replaced.
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
