Question about HP LaserJet P2015dn Printer
Paper pickup in tray 2 not working
The printer is having lots of trouble picking up paper, it will sometimes print one or two sheets, but then gets stuck. I've followed the directions on the HP website for cleaning the pickup for tray 1, but it has not solved the problem, so I'm guessing that the issue is the paper pickup for tray 2. I've looked around in the back but cannot see anything obvious.
Any ideas?
    Genius:
  • 2,120 Answers
This is an issue i've seen many times.
The gear that drives the lower tray barely conacts the gear in the main body.
You cannot buy just the gears, you will have to buy a new option cassette assembly.
If you lift the printer off of the lower cassette you'll see the suspect gears.
Posted on Dec 20, 2008
Helloo my problem is pape jam machin show j21 / 00 how i stop this
You have not provided your printer model, nor have you described where the jam occurs, so you get a generic answer for the most common causes.
1. The printer tries to pick up more than one sheet at a time. This is caused by a worn-out separation pad on the paper tray (usually this is a small square of cork sheet).
2. The paper does not enter the printer properly because the pickup roller is worn out.
3. The paper turns to the side somewhere in the printer. This is caused by a foreign object (usually a shred of paper) at the point where the paper turns. Sometimes you can pick the offending object out without major disassembly - you may have to make a hook out of a piece of wire to get it.
4. The paper accordion-folds at a roller set. The roller set is worn, or there is a problem with its drive gear. Accordion jams at the output roller were the most common mechanical problem with HP Laserjet 4 printers as they aged.
5. In the early days of computer printers, paper sometimes had a tiny burr on one end that would hang up and snag along an extra sheet on pickup from the tray. The fix was to remove the paper stack and turn it around so the burrs were on the other end of the tray. Sometimes fanning the paper stack before putting it in the tray would help. Paper manufacturing has improved since then, so these problems are relatively rare today, but if you have an old box of paper reams, it could be an issue.
May 02, 2012 | Office Equipment & Supplies
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
1320 HP Laserjet Still Won't Pick Up Paper
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
Oct 09, 2009 | HP LaserJet 1320 Printer
Does not pick up paper from the tray
How much paper gone throught the printer since it is new?
usually the pickup roller is good for 10,000-15,000 sheets.(20x500 sheet pack). if the printer went throught that much paper, then the pick up roller need to be replaced.
if not, make sure there nothing stucked on the pickup roller, and the roller is not shining (it need to be soft and rough).
Apr 18, 2009 | Dell 1700 Laser Printer
Manual feed pickup
replaced the manual feed tray separation pad (it is right under the pick-up roller). The HP part # is RG5-2703. First remove the pickup roller then you can pops it out with a small straight slot screw driver.
Jan 23, 2009 | HP LaserJet 8150n Printer
Will not print. says out of paper but there is paper in the tray.
this is indicate that the roller is having some kind of problem.
open the backdoor, make sure there is nothing preventing the roller (should be 3) do its job.
take out the paper from the paper tray. make sure there nothing in the way of center roller path.
re position the paper. load enough paper, so that the paper is right under neath the center roller, remove 2 sheet. try to print. if it pickup the paper, then it is telling you that the roller need to be replaced. if it still having problem pickup the paper. then there is something else we need to investigate.
Hp always being having problem with their printer roller since day one. over time the roller become smooth, and not able to pick up paper.
if the porblem presist, please repost it in this thread. so I can help you to solve the problem.
Nov 13, 2008 | HP PSC 1315 All-In-One InkJet Printer
BizHub 450 Universal tray won't pick up paper
Sounds like either a loose drive connection or there is some trace piece of paper still left in the device.
BNe sure not to overload or UNDERload the tray as well.
Aug 25, 2008 | Konica Minolta bizhub C450P Laser Printer
Paper feed
Make sure you fan the paper before putting it in. 20 sheets is usually about right for these printers.
If you put labels in the printer. Only put a few sheet in at a time and put paper stock below them.
May 22, 2008 | HP DeskJet 820Cse Printer
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet P2015dn Printer Logo
340 people viewed this question
Clive
Clive
