Question about Hotpoint Aquarius WMA42 Front Load Washer
Washing machine not draining therefore not spinning
Aquarius wm 800 12 does this washing machine have a filter if so where is it thanks
  • Hotpoint Master
  • 3,463 Answers
You will find the filter located inside the large black hose at the lower right rear of the m/c.
Remove lower panel and you will see the hose there.
Undo the large clip and remove hose and clean filter.
Plz rate this solution
Thanks
Posted on Dec 19, 2008
Why dosent. My washingmechin spin
Wm has 2 drain first before spin. Check drain pump filter is clean . Located front bottom of wm.
Aug 11, 2014 | Kenmore Washing Machines
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
My mothers Hotpoint WM 52P will not drain water out or spin???? Does this mean brushes??? poppywitch
no take the sump hose off from the tub off the machine and check for blockages the machine wont spin unless it can drain the water out
Jun 05, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarius wash system plus wm 63
First of all lay the drain hose into a bowl or bucket to drain off.
Then take off the plate at the back of your machine and you will see a pipe running from pump to drum.
Where it meets the drum there is a filter inside which you can check for debris. also take off at the pump and check inside pipe & pump.
Happy to help further if required.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius 6kg washing machine, i need to cancel a progeamme and drain the washing machine as their is a sleeve caught in the door and water is coming out but don't know how to please...
hiya
if the model starts with wm then you should set the timer knob just before a spin setting and it will empty out.
if the model starts with wma,few or wf then you will have to hold in the start button as this will cancel the current cycle and should start to drain.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Hotpoint Washing Machines
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
228 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
