Question about Polaroid i733LP Digital Camera
Background is overexposed
About 20% of the time i take a picture the pictures have a bright white backround as though the flash overflashed.
You can still see the subject you took the picture of but the picture itself is useless.
    Problem Solver:
  • 14 Answers
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Posted on Dec 27, 2008
How do you remove the white areas of a shot from flashing black when you look at the image?
What you're seeing is blown-out highlights. These are areas of your picture where the bright stuff (highlights) have been so overexposed (blown-out) that all detail has been lost. That's not necessarily a bad thing, but usually is. The proper fix is to reduce exposure slightly. Lost details in the dark areas are usually considered more acceptable than lost details in the bright areas.
If you simply don't want to see the blinking black/white parts of your picture, simply press up/down on the multiselector to select a different view of your picture.
Apr 25, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Bright white exposure
This may be a ccd problem.
See this link.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Aug 06, 2008 | Canon PowerShot A80 Digital Camera
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Overexposed picture
My guess is the the EV setting is on the + side and not neutral (0). Either that or Image Adjustment setting is wrong. Check EV by pressing the +/- button (right side near On/Off switch). Hold EV selector and make sure 0.0 is in the display. Let me know if that is not the problem and I'll assist you further.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Mar 18, 2008 | Nikon Coolpix 5700 Digital Camera
SB-29 speedlight overflash
Go Manual.
Set F Stop to higher number.
Can also lower the ISO.
atdlee@netzero.com
Jan 16, 2008 | Nikon Macro Speedlight SB-29 TTL Ring...
Time for new flash??
the camera's light sensor or metering system, for correct flash exposure is no longer working, that's why your shots is either black or white (overexposed or underexposed) the flash firing has loose its control because of the defective sensor, it now only depends on the charge current of the flash capacitor. If you'll wait longer time the charge is maximum picture result will be overexposed(white), and vice versa, less charge, dark result, have the flash assy replaced. Daylight no problem, it doesnt use the flash circuitry, thanks
Jul 28, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Problems with my camera's flash...
Well if you have time and the camera manual with you check out the settings to make sure you have not missed anything. You could also check out the Fuji Tech Support at the Website Not much else you can to unless you can find a repairer- after all you re in the land where they are all made.
Jun 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
My picture is too light (overexposed).
If you're using the forced flash setting, it may be too bright. Try setting the flash to Auto. If you're facing a bright light source, you may need to shoot your picture from a different angle. Use Image Expert to adjust the picture's brightness, as described on page 9-4. Set user mode to Manual and adjust the camera's exposure setting.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Polaroid i733LP Digital Camera Logo
243 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
