Question about Panasonic DVD-S25K DVD Player
My Panasonic s25 dvd player is not working. Yesterday it was fine, today I get a no disc message then it says H07. I hear things moving inside but the disc will not play.
  • Anonymous Apr 04, 2009
    I have the same problem
Kimi
  • 277 Answers
SOURCE: Troubleshooting -- Displays H07 code
The H07 error message in Panasonic DVDs means problem in the motor. It can be something like "motor isn't spinning-up" or "spindle motor problem". When you call Panasonic, they will tell you that they cannot tell what H07 means until a technician look at it. Obviously, they won't admit it is a known problem. Estimate cost: from $50 to $70 dollar to replace the motor + labor + tax.
Posted on Dec 26, 2005
petraman7
  • 1175 Answers
SOURCE: Panasonic dd-s25 won't play dvd.
HI...
Have you tried reg.CDs to see if those have trouble too?
I would say that the lens assembly has got debris or a filmy substance over the lens.
If you're not the least bit technical , dont open the unit.
It will require that the cover gets removed and the top DVD spinner plate gets removed so that the Lens can be cleaned.
The chrome rails that the DVD reader runs on would need cleaing too.
Posted on Mar 04, 2009
SOURCE: hi my panasonic dvd wont play and the message is H07. any ideas?
hi you have a problem with the spindle motor
look this page: http://www.elektr0n.com/dwm/doku.php?id=how_to_fix_the_h07_ho7_error_on_your_panasonic_dvd_player
Posted on Jan 06, 2010
  • 189 Answers
SOURCE: Panasonic DVD-CV52 Multi-disc DVD Player? H07
HELLO
Ah, the infamous HO7 error! This is to do with the disc motor and there is a solution which MIGHT work for you (it did for me).
You need some sewing machine oil and a precision oiler. Don't be tempted to use WD40 as it will get everywhere and is not really suitable. Just put a couple of drops into the spindle (disc) motor. Where the shaft goes into the motor and leave it for about an hour or so then try it again.
The only real solution is to replace the disc motor, but this can be a fix depending on the situation. Give it a try - what have you got to lose?
GOOD LUCK!
Posted on Apr 14, 2010
fieldy14
  • 456 Answers
SOURCE: Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
Posted on Sep 03, 2010
Sep 03, 2010 | Panasonic DVD-RV62EBS DVD Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Player stops. H07 appears.
This is a problem with the spindle motor,you can locate where the spindle goes into the motor and spray with wd40 leave for a few mins.
Nov 08, 2009 | Panasonic DVD-RV32 DVD Player
My dvd player do not play. it says no disc, no matter what I do
I just removed the top part and clean the laser beam with Q tip and after that it started to work back again.
Mar 19, 2009 | Panasonic DVD-S25
HI...
Mar 04, 2009 | Panasonic DVD-S25
Error message H07
The spindle motor is defective. Open the cover and see if the disc spins when it loads. If it doesn't, give it a spin in a clockwise direction immediately after loading the disc.
Apr 05, 2008 | Panasonic DVD-RV32 DVD Player
H07?
Replace Spindle motor.
Sep 14, 2007 | Panasonic DVD-S35 DVD Player
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Dec 23, 2005 | Panasonic DVD-CV37 Multi-disc DVD Player
Panasonic DVD-S25K DVD Player Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
