My ln32 450 samsung monitor shows pc and mode not supported in the middle when connected to my hp laptop
  • 111 Answers
Firststart it in safe mode and run the add hardware wizard anfter windows finds it and installs the monitor reboot then set the video adaptor at 600 by 800 mhz at 60 hz then adjust it from there
Posted on Dec 19, 2008
Samsung LCDTV 932MW has every source greyed out except for TV and Ext. even when a VGA cable is connected.
the PC must be put into external VGA mode.
fn +F4, (read your manual on HP PC first? laptop , and unstated laptop, just HP, is not a laptop model.
then connect the laptop to any monitor made, with VGA>
does that work>?
1: yes, then its not the PC side. (assumes resolution is legit to TV )
2 no, then is PC issue. (or cable bad)
vga pin 10 is ground, there is no need to short ground to ground.
if the cable is bad it will fail test 2 above too.
do not short VGA pins, or you will blow to H3LL the RGB drivers.
or the sync drivers. never short things you don't understand , ok>
the TV grayed out, id guess, means, no sync from PC.
both sync pins dead, (on PCs monitors it shows, NO SIG or NO SYNC or out of rage or shows going to sleep.
that brings up the ugly specter of sleep, make sure the laptop never goes to sleep, use presentation mode.
like this.
CP, go to control panel w10
click power
click advanced,
turn off sleep and hibernate, and now you can run a projector
or TV endlessly.
there you go,m how to test and solve PC problems and more,.
tell more test more and we can do as deep down the rabbit hole
you wish...
cheers and good luck.
Apr 05, 2018 | HP Computers & Internet
My monitor on my hp8300 stays in sleep mode
you need to turn off sleep mode its sounds as if its on a timer setting.
Apr 22, 2014 | Samsung Computers & Internet
No input signal recommended settings hp vs15 monitor 1024x768 60h
old monitor 1280 x 1024
power light on?
OSD work?
if it said on the screen no input sig, then that is 100% true
the PC is not sending output.
check the video cable connections both ends
then if bad, boot PC to safe mode. does that work.
then maybe you set the PC graphic resolution too high for the monitor. use safe mode to set new , legal resolution
1280 x 1024 is max, do not exceed, the horz, vert, reso to the left here. if you do the monitor , will display, out of range. errors.
im confused, you show HP monitor then Sam.
why ?
my guess is HP question posted in SAM section.
so here is my HP answer
1280 x 768 @ 75Hz
if your PC or other device exceeds any of those. this old monitor
will go blank.
HOR, vert and refresh rates max.
to solve this riddle, set the PC to
1280 x 768
then connect monitor and bingo.
but there is a chicken and egg deal here.
if the display car is over this, as most new systems are.
then use safe mode to set the resolution to 1280 x 768
and reboot to normal mode.
boot and it F8 , safemode.
Sep 25, 2013 | Samsung SyncMaster 960BF (White) 19" LCD...
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Jan 12, 2013 | Samsung Q32032P PC Notebook
Hi I BOUGHT NEW Samsung SyncMaster P2070 20" LCD Flat Screen Monitor , AND I HAVE HP COMPAQ AND THE MONITOR NOT COMMUNICATE WITH PC
http://support.dell.com/support/edocs/video/p56135/en/connect.htmhttp://support.dell.com/support/edocs/video/p56135/en/connect.htm
you Monitor uses the DVI-I Port this link will show you what it is. you will need a adapter that can connect to VGA port on your PC. unless your HP has a DVI port. You need a DVI-I to DVI-I connection to work if it has one
this link will explain the difference of the DVI ports...
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=51555&prodTypeId=329290&objectID=c01525281
the adapter you need is a DVI-I to vga ...
opensources_1.jpgcheck the pins on both the pc and the adapter and monitor
Sep 14, 2011 | Samsung SyncMaster P2070 20 inch LCD...
I have a Samsung SensR470 laptop and i have linked up the VGA, audio, and power cables but the monitor is not showing anything. when i turn it on, it just goes into sleep mode or otherwise shows the...
its because you failed to read the Samsung manual on your PC
go there and read, it has HOT key , all laptops have a hot key
Fn key that turns on the external display VGA jack.
on rear of this SAMSUNG.
SLEEP MEANS THE PC IS NOT SENDING THE HORZ AND VERTICAL, SYNC SIGNALS. AT ALL.
THAT MEANS WHAT>?
It means the PC, VGA jack is turned off.
bad cable
bad monitor.
The PC can also be bad VGA chips, or worse,.
your first failing here is not saying why you are using VGA jack
is the Laptop screen dead too> (my other shoe falls off)
dang that be nice to know , no?
or like we do run that VGA to a projector? for say doing power point presentations, (done many before retired)
RTM, the manual is free to read any time of day, 24/7
each PC maker uses there own rules here, its there call
there design and their rules.
my HP its, Fn+F4, (toggle:, internal, external ,both or auto)
but yours is Samsung, ask them. or learn to use google?
Jun 10, 2017 | HP w1907 LCD Monitor
Video monitor says there is no input and to check the cable connections. connections and cable are good. Does that mean the video card has probably gone kaput?
It may mean that the video card is bad , but not always the case. Start with borrowing a known good monitor from a working pc and then test the following ... video card, memory chips ect. Does it show screen ever or only goes away in the middle of boot up? try booting in safe mode F8 key if it happenes in the middle of boot up.
Sep 25, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Broken HP pavillion dv7 screen refuses to recognize the remote mo
try connecting another monitor. If it does not find it automatically Hold down the fn key and press the F4 key this will toggle through 3 different modes. main screen only, Mirror main screen on 2nd monitor, or Extend desktop to 2nd monitor.you can set the resolution of each seperately. Right click on desktop and choose proprties or control panel>display
Sep 08, 2009 | HP Pavilion dv6000z Notebook
Compaq presario show straight line in middle of monitor
That happens only when there are loose connections and/or a problem like you dropped the PC or hit it hard. It MAY be because of moisture.
I guess you need to show it to an authorised HP doctor.
Oct 17, 2008 | HP Compaq Presario 1700T Notebook
Samsung 19" monitor 913n
screen has about 12 small opening page instead of a normal one page
Jan 11, 2008 | HP Pavilion dv9005us Notebook
Computers & Internet Logo
74 people viewed this question
Alun Cox
David Payne
David Payne
