Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Start up hi can you help me please ,,, i,m haveing problems starting my pc , what happens is when you turn it on it powers up for about 5 seconds then switches off ,, i still have a power light on the motherboard showing green , so i guess the psu is ok , there was,nt any hdd in it or memory when i got it ... if i keep turning the power on and off the same happens on for a few seconds then nothing ,,,, would you say this is a motherboard problem ??????? motherboard is a asus A7V8X-MXSE.....
  • 1 more comment
  • kawasakiz128 Dec 19, 2008
    hi jonages3 ,,, i,ve try what you said ie changed battery checked and cleaned the processor block , and checked hdd, all that happens is it trys to start but wont ,,,, apart from the motherboared not sure what else it could be ... any thoughts let me know please...............
  • Eviltangent Jan 27, 2009
    Same problem, except I refit the cpu fan plug into the board, and fan kicked on... Power seems to stay on, but nothing happens. Monitor doesn't come on, and the cpu heatsink isn't even getting warm to the touch. I pulled ram, and no beeps were issued. (yes pc speaker is plugged in). This happened after a routine cleaning, which I've done a thousand times before on this and other pc's. First time this has ever happened to me. Thanks in advance.
  • Mark Robinson May 11, 2010
    take the RAM out and fire up the PC again.....do you get any beeps ?
    Scholar:
  • 83 Answers
Good day!
I have the same asus motherboards I check first the memory if it is clean next is battery. Try to check also the unit if it is clean.
Secondly, after doing my first suggestions if it doesn't work try to check your processor maybe the lock 4 sides are not mounted properly. resulting to sudden turning off. or sometimes electric current disturbance.
Third, Ty to check your Hard disk drive ( HDD) may be the cable connection has he problem.If you use sata try ti clean the plugs. For the IDE you may use cleaning procedures too.
Thanks,
jonags
Posted on Dec 19, 2008
POWER IS ON UPON START UP BUT AFTER INITIATING TO DESKTOP MENU,NO SCREEN IS ABLE TO SEE BUT WHEN I ENTER CTRL,ALT&DELETE THE PARAMETERS HAS SCREEN.PLEASE HELP.
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Aug 06, 2011 | Computers & Internet
The screen on my laptop HP 6930 has gone black all of a sudden, but starts up regularly, I need help ASAP!
Aug 06, 2011 | HP EliteBook 6930p Notebook PC
Laptop wont even start to power up when power buttonis pressed the green power light comes on for about 4 to 5 seconds then goes off the same thing happens with battery or power packthe same thinh happens...
Problem may be a simle matter of the battery contacts needing to be adjusted so they make better contact for charging and use. Use a needle and ~GENTLY~ raise contact bars on either laptop or battery.
Jul 18, 2011 | Dell Latitude D610 Notebook
When I start my computer it runs for 5 seconds and turns off tried a new power supply but same thing happens
Welcome to FixYa
If you already replaced the power supply of the system then the next most logical step is to replace the motherboard. Power problems with computers is usually caused by a defective power supply or motherboard.
Hope this helps
May 02, 2011 | Compaq Presario S4110CL PC Desktop
Hi. I have an acer aspire one 751h which will not boot up. When you press the power button it starts up and goes to the safe mode start up screen. Pressing any of the available options will get you the...
If you already tried all of the options available on advance boot option menu and the same thing happened you'll need to do a repair on your windows. Please tell me what version of windows are you using then I'll give you possible resolutions to this problem.
Apr 23, 2011 | Acer Aspire One PC Notebook
Hello I have a problem with my HP Pavillion m9277. When I switch the computer on it goes ok for about 5-10 seconds, cuts out for 5-10 seconds and then starts up again, but there is also nothing happening...
Hi Friend, As you have mentioned that your system goes off after 5-10 seconds and turns on again. I would recommend you to please unplug all the cables from the desktop and press and hold the power button of the system for 30 seconds, release it after 30 seconds and make the connections again.
Start your system again and check if your issue is fixed or not.
Also I would like you to check after turning on the system do you get any beeps from the system after which it goes off
Dec 08, 2010 | Computers & Internet
No screen display when i am starting the my system.it not started
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Jul 12, 2010 | Dell Vostro 1500 Notebook
Hi. I have an Inspiron 1300. Suddenly, the screen ...
Black screen is often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
May 21, 2010 | Dell Inspiron 1300 Notebook
Can't start and also stop my lenovo sl400 after running of battery power. Please help
Hi lim_bunly, try to isolate the problem by removing the battery from the pc and use only the power adapter to turn on the pc. If it work, then turn off again the pc and remove the power adapter and push the power button for 5 seconds and insert the battery only if it work. If it doesnt then there is a battery problem, you can call their tech support hotline 1-800-426-7378 to check the battery.
Hope this helps....
May 08, 2010 | Lenovo ThinkPad SL400 Notebook
Screen only turns on randomly during start up, led lights are lit, laptop sounds like it wants to turn on and stops, then tries again, then stops. Problem happens about 9 out of 10 start ups, and when it...
remove battery, press and hold power button for 5 seconds, then wait 5 minutes, put battery back in securely and try again. If it powers on, try and look at the power meter to see if it is registering the power supply. You could have faulty memory chip or faulty power supply
Nov 30, 2009 | HP Pavilion dv6000z Notebook
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
157 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
