Question about RCA RCU800B Remote Control
SISTEM LINK4 i,m need code remote control sistem link4 send to my e-mail please to my tv philco hitachi model;PC1441 NUMBER SERIAL 298414
SOURCE: lost my code book for rca univ remote
Well I know this is a few months late but go to to find the codebook. Usually the model number of your remote control is on the inside of the back lid. Just take it off and flip it over.
Posted on Sep 01, 2008
  • 51 Answers
SOURCE: Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing
Posted on Nov 08, 2008
SOURCE: Need a code for Hitachi Ultravision TV
hold power and tv button same time
until power buttton stays on then
slowly hit power button until tv turns off then hit stop button and tv will work with remote
Posted on Jan 16, 2009
SOURCE: programming my remote
go here for your codes to any rca remote
Posted on Mar 22, 2009
  • 5568 Answers
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Posted on May 17, 2009
  • 814 Answers
SOURCE: rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
Posted on Jun 22, 2009
0 characters
1 Points
Could RCA remotes be programmed for Precision Tv?
Try the below website.If you can fine your tv from list you can programme it.Try using the auto programme.
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Sep 13, 2010 | RCA RCU300WBL Remote Control
Need codes to t v
Hi you will need the model number of the remote they make about 30 ir models but here is a link to the codes just choose the model remote and click codes then scroll down in the television section to hitachi for codes.
also here are some codes for dish net remotes/hitachi tv's > 523, 549, 554, 555, 585, 627, 638, 654, 655, 658, 756, 786, 788, 789, 790, 791
Jan 31, 2010 | DISH Network IR Remote Control
I need codes for TS-RC444 for my Sony TV
go to and send them an e-mail aking them to to send you the instruction manual for your remote. They can probably send it in PDF format to your e-mail address. Just click on the "contact us" tab and make sure you include the model number for your remote.
Oct 23, 2009 | Trisonic TS-1666RFS Remote Control
I Dont Know My 3 Digit Device Code To My PHILCO URC-2070 Please Will Someone Help Me
On most universal remote control, you will find the procedure to enter the builder code OR a procedure to pass through all the code of the remote, one by one and pass to the other TILL you find the right one. It happen to me numbers, a bit upsetting procedure but you'll find out...
Oct 09, 2009 | RCA 4-in-1 Universal Remote Control
Philco remote URC-2070/admiral tv code?
Asked someone else who knew the three numbers to program my tv.
Nov 26, 2008 | RCA 4-in-1 Universal Remote Control
Code for Watson has pdf of all manuals with codes
Nov 20, 2008 | Radio Shack 3-in-1 Easy-to-Use Universal...
Rca remote
Try with the other sistem of find it with code search
Good luck
Nov 02, 2008 | RCA Universal Remote Control
Code for philco tv
Remote codes
good luck
please mark the post with a fixya
Mar 17, 2008 | DISH Network IR Remote Control
Universal remote code for sony TV
can you send an pic of it though my e-mail adress
Dec 21, 2007 | Remote Controls
We have a Haier TV model 3 HL32R2a, the cable remote no longer turns the set off or on or controls the volume. We can only do that with the tv remote. Tried putting in the universal code, and the Haier code and it didn't work. Please help.
Dec 09, 2007 | One For All URC-4330 Remote Control
RCA RCU800B Remote Control Logo
27 people viewed this question
Top RCA Remote Controls Experts
andy williard
andy williard
Are you a RCA Remote Control Expert? Answer questions, earn points and help others
