Question about Kenmore Dryers
Kenmore dryer doesnt heat
I just bought a used dryer, it fine the first couple of loads, but stopped heating what did i do wrong?
    Problem Solver:
  • 10 Answers
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Posted on Dec 19, 2008
Intermittent heating on different cycles?
After a 12-year service life it probably is time to retire your Maytag dryer.
Feb 23, 2014 | Dryers
I have kenmore he2 dryer. it works fine except stopped heating. how long should heating element last? what else should i check?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
\[0-
Mar 31, 2011 | Kenmore 62602 Electric Dryer
Dryer runs but the air doesnt heat up, what problems can it be? i have a kenmore 800 series and it worked fine then just stopped heating. i pulled it out checked the vent to make sure it was clean.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 02, 2010 | Kenmore 800 7982 Dryer
My kenmore dryer heats but doesnt spin i popped the top an the belt looks fine is it the motor or could something else b wrong
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Kenmore 62622 Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore HE4t gas dryer will not heat. One load
The Sensor for heating element cut-off is bad. It wrongly detects the unit is overheated so it signals to inhibit the gas valve not to open. Since it is not opened, gas is not burnt through the manifold hence not heat why the machine is tumbling. Good luck.
Apr 18, 2010 | Dryers
My kenmore series dryer does not heat. the timer
the heater element has two parts to the heat coil if one of the coils breaks it will not get hot enough to heat the load all the way to set of the sensor to stop . it seems like you need to replace your heat element . if you want to know how to take it apart i have a couple of posts that tell how or reply back the coil costs about 89 dollars you can get one pre strung for around double the cost
Feb 25, 2010 | Kenmore 63942 Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
161 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
