Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP Goes Black then 3 Flashing Lights of Death
I have an HLP5063W series Samsung DLP TV. The TV will turn on for about 3-5 minutes then the screen goes black. Sometimes balck and white remnants of what was on still remains before the TV cycles on/off 3 times to attempt to "fix" itself. Then the christmas tree shows up (timer, lamp standby/temp flashing). I immediately thought it was the lamp, so I replaced it with a new one (old one had over 10000 hours - nice!). Same problem persists. I am hoping it is the ballast and not the DMD board, but what makes me think it is not the ballast is the remnants on the TV. The timing of the shutdown is 1) all controls, whether on the TV on the remote fail but the TV is still on. 2) The screen goes black but the lamp is still on. 3) The lamp goes out when the TV shuts itself off. Once this occurs, the TV must be unplugged for awhile to reset, but it happens faster the next time. Could that mean a bad fan? The fan which cools the lamp is working. The TV is out in the open, so it should not be an overheating issue unless there is another fan in there somewhere that has failed. Can't be the shutoff switch on the back panel. Any ideas? Please don't say DMD.
  • 5 more comments
  • russjwhite Dec 19, 2008
    I do not have any of the tools which you guys talk about. Would the manual still be helpful? If so, where can I pick one up/download a copy of the service manual?
    Does the service manual explain how to test the components? What kind of tools do I need to test?
    I have purchased the service manual for the television. Is there anything I can attempt to fix the problem while I am waiting for the manual to arrive? Any additional information you can provide on diagnosing and remedying the problem described would be helpful.
    I replaced the color wheel about two months ago and it has worked fine, can hear it spinning up. The ballast does arc when the TV starts after being cold for about 15 minutes. Cannot restart the TV without leaving it unplugged for awhile. Even unplugging the TV for a few minutes, when plugging it back in it tries to restart itself 3 times and fails.
    I forgot to mention that after I replaced the color wheel, the set started playing this melody whenever I turned the TV on or off. Don't know if that has anything to do with it.
    So here is what I know. It is not the lamp and it is not the color wheel. The TV does work, for awhile but then something fails. The ballast fires to start the TV and lamp continues to shine after the screen goes black. With all this in mind, do the symptoms seem to point to one internal component that could be failing, or could it be just about any component has failed and I need to test everything through a process of elimination to find the broken component?
    With TV prices what they are, would it be more economical to simply purchase a new set? If so, is there a brand or model you would recommend that does not have as many issues as others? It seems Samsung has quite a few problems and I would really like to be able to trust that my TV is going to last atleast 5 years.
    Sergeant:
  • 233 Answers
Well, im not supposed to say this, but DMD.
sorry, but it sounds like it is overheating (there is usually more than one fan..one for the lamp, one for the DMD and one for the main board), either that or the color wheel is stopping / failing...
it may be worth it to take a look inside and just wait for shutdown so you can go from there!
Posted on Dec 19, 2008
    Genius:
  • 1,199 Answers
Replace the color wheel and the tv should work fine
  • 10,594 Answers
Your TV needs qualified and experienced TV Tech Guy to rectify the problem as it seems complicated.
Digital processing board and System control section seems defective and need to be checked.
  • 2,427 Answers
It most likely the color wheel,, this will account for the tv going black and whit, you may need to replace it.
  • 495 Answers
With lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
  • Samsung Master
  • 19,396 Answers
What is called ballast on the rear projection TV is a small power board that powers the lamp, this can be defective, but also main PSU can be cause for the problem.
There are also a couple of ICs that must be tested when you get sudden shut down.
The best thing to do is getting a copy of the service manual,=.
  • Ginko
    Ginko Dec 19, 2008
    It can be still overheating, but it is more common having a problem on boards because a faulty capacitor, or a faulty IC returns a bad voltage or fails only after a while.
    In this case you need to follow the troubleshooting diagrams on the service manual, that will drive you in testing the ballast, the PSU, and a couple of ICs on the main board.
    You can get the service manual for $7.5 on Ebay(Samsung SM-HLP5063W SERVICE MANUAL), or order for $15 or so from PArstore.
  • Ginko
    Ginko Dec 19, 2008
    The service manual has what are called troubleshooting diagrams.
    They will tell you what to do starting from a fault description.
    To test components you mainly use a Multimeter
    The point is that you should not do it yourself if you do not have the necessary background, a technician must study and practice several years before being able to fix this unit without damaging it or endangering himself and the final user.
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My samsung 50 dlp tv has stopped working it will come on for 2 minutes i will get a picture and then i lose the picture i still get the sound but the tv goes black what is the problem there are three...
on dlp units there's a bulb that needs to be changed
avery 2-4 yrs..try and do that first..if that wont solve the problem..then try the color wheel if u here a humming noise before it shuts down.
any questions--->bhzrdg@yahoo.com
Jan 24, 2010 | Samsung Remote Control
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Sep 17, 2009 | Samsung Televison & Video
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Aug 06, 2009 | Samsung Televison & Video
Samsung HLP5063W 50" DLP Projection TV has a 3 inch black band
Did you check the picture format and adjust for 16:9 in the menu?
Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
