Question about SanDisk Sansa Clip MP3 Player
My Sansa 2 gb player won't charge
My Sansa 2 gb player does not charge when I connect it to the computer. It starts to charge and within one minute it stops and screen displays connected. any solutions?
  • 8,596 Answers
Make sure the hold/lock switch is not engaged.
Try another USB port on your computer.
If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    My sansa clip 2 gb doesn't work , when i plug the usb cable my sansa starts charging battery but I can't pass songs to my sansa because it doesn't recognize it , what do I do?
    Hi
    Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If it is visible then try a reset and try again. If not then reset the player while it is connected with the system. This will resolve your issue.
    Hope this helps...
    Sep 14, 2010 | SanDisk Sansa m250 MP3 Player
    Sansa c250 mp3 player connects and will not charge
    It takes a while. Try leaving it charged over night, then tell me if you have any problems.
    Sep 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
    Sansa e250 wont charge when plugged into the computer.
    Sounds like the internal battery needs to be replaced.
    Hope this helps. Good Luck!
    Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
    MP3 Sansa Sandisk 1 GB
    If it won't charge, then:
    1) USB connector is damaged
    2) USB port is damaged (Have you tried other port and/or other computer ?)
    3) MP3 Battery is damaged
    May 27, 2009 | SanDisk Sansa m240 MP3 Player
    My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
    This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
    Make sure that the USB cable is properly plugged in and use the original cable.
    Computer in Hibernation mode
    Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
    USB Port 2.0
    Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
    USB Port location
    Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
    Battery
    Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
    Latest firmware
    Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
    I hope this helps, and don't forget to rate the answer.
    Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
    My sansa e250r will not connect to my pc I plug it in, it starts to charge but the computer doesn't even know it's plugged in kinda, nothing comes up, bearshare won't connect and nothing in my computer,...
    To get the computer to recognize the player, you must engage the hold button and hold the rewind and menu button at the same time. Let me know if you need more help.
    Feb 27, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
    How do I charge my sansa?
    all you do is put the usb in the mp3 and the computer and then the battery will just start to charge it takes about one or two hours
    Nov 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
    SanDisk Sansa Clip MP3 Player Logo
    53 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Computer Repairing
    Computer Repairing
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
