Question about Dryers
Well I just brought a used dryer, its an older model (kenmore) anyway I dryed a couple of load now its not heating what do you think I did worng?
  • Greg Angeli
    Greg Angeli May 11, 2010
    Hi and welcome to FixYA!
    Is this a gas or electric heat dryer?
    Genius:
  • 1,122 Answers
YOU NEED TOO REMOVE THE BACK AND CHECK THE HEATER BOX FUSE AND ELEMENT,ALSO CHECK THE WALL VENT AND DRYER VENT TO MAKE SURE THERE NOT CLOGGED WITH LENT-MIKE
Posted on Dec 20, 2008
After every load, the dryer lint trap is wet and there's water condensation on inside of the glass door even days after use. I've thoroughly cleaned the ducts and the lint filter as well as inside where...
Is it gas dryer?
If it is might be problem with the heat exchanger, Water is one of the by products of combustion.
By chance do you have a Carbon Monoxide sensor?
Easy way to tell if a cracked heat exchanger is the problem.
Other thought I have is the dryer heating up when its drying, if the heater isn't working and you are throwing wet clothes in there that could be part of the issue.
a couple thoughts anyways
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Kenmore 7.3 cu. ft. Electric Dryer w/...
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 16, 2012 | Kenmore 659 Electric Dryer
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Aug 29, 2010 | Kenmore Dryers
Drying clothes are cold and not getting dry
Bad heating element or thermal coupling. You need to take back of dryer off, unplug first. Then check with a tester all thermal coupling and heating element. You won't know until dryer is troubleshooted.
Jun 01, 2010 | Kenmore 63942 Dryer
My Kenmore model 70 dryer works with the timer but the auto-dry feature will never turn off the dryer. I'm assuming that this is a moisture sensor problem. Info from the tag inside the dryer: type:...
are your clothes drying?when the dryer heats up the heat shuts off then the timer will move,when the heat starts the timer stops,no heat no timer movement.when did you last clean out the dryer?you need to clean out the vent line if it's a long run i use a leaf blower to clean it out,you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year so you don't have a fire and your clothes will dry on time and you won't have any problems like this,try running it with the vent line off to see if this helps.you also could have a bad thermostat but you should clean it first anyway
Apr 17, 2010 | Kenmore Dryers
I think the moisture sensor is bad in my kenmore he4 electric dryer. It works well on timed dry but does not stay on when using the automatic settings. It is still heating fine, it just stops prematurely...
it is a problem with how you are loading the unit. you must use the same type and weight of clothes or the sensor will think the light items are dry and then shut the unit off.
try to do a load of all towels and see what happens on the automatic cycle. if it does well then you just need to sort your clothes better.
the sensor is just 2 metal strips and will never fail.
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
Is not heating
i think when this happened to my sister it was the heating coil. her dryer caught on fire. don't run it unattended.
Aug 01, 2009 | Kenmore 700 6972 Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Dryer heating element
usually if it heats up but long dry times ,,air flow problem inspect exhaust hose and vent s should resolve problems...
Dec 27, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
