Question about Bestec (ATX-250-12E) 250-Watt Power Supply
Powers on and turns off 10 - 20 seconds ?????
I have an e-machines 610 and my power supply is a bestec atx-250-12e...the problem i am having is that when i power the pc on the green power light comes on and flashes, then after about 10-20 secs it turns its self off ??? during the time the pc has power i cant even open the dvd drives basically no power is running to the drives..ive even tried just putting power to the drives and still no success in opening the drives...
do i need a new power supply or do i need a new motherboard ???
thnxs for any help ****
  • white_wolf01 Dec 20, 2008
    have already tried the it with the cd and dvd drives...also with the floppy drive and just with the h/d. but same problem happens...also the cpu fan is alittle bit loud..so guess it is the cpu unit that is dying on me then...cus i really dont want to be buying a new motherboard....
    Problem Solver:
  • 6 Answers
Your power supply is probably fried. I had a similar problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Posted on Jun 20, 2009
  • 111 Answers
Check the power supply first, unplup the cd dcd components and try your pc this way,
Check the cpu fan also as this sounds as if the cpu is reaching critical heat ranga and is shutting down the system to protect it self
Posted on Dec 19, 2008
  • Leslie Dec 20, 2008
    Have you tried it with a new Power supply?
    Try it with a new new power supply!
    If the problem persist after you have tested it with a new Power supply try these steps below:
    Have you tried it with just the keyboard and video?
    Boot it into the bios and check the speed of the fan and cpu temp. (it is very rare for a cpu to die before the mb)
    If the fan is not running at its proper speed try another one,
    (P4's require a min. of 300w and some AMD's are higher to maintain a stable system.)
    Monitor it for several minutes in the bios, watch for fluctuating speeds and cpu temp. changes, if these remain constant with a new cpu fan and the problem persist, It is probaly not the cpu
    The cpu will remain constant in voltage use and temp.(- Provided the fan is good!) If it is good,
    If these do not fix your problem then consider a new mb
When compter is turned on the only thing that runs is the fan. The monitor does not display anything. Can you please tell me what you think happend. Husband took out the power bestec atx-300-12e. and...
power supplies are common failures..a 300Watt ATX power supply is not very expensive these days so it would be an inexpensive way to see if this is the problem..the brown spot concerns me though..seems maybe you have a filter in the supply that may have leaked electrolyte...if you have another computer with the same type of supply in it..you can try it..as long as the plugs are the same and the wattage is the same or higher
Jan 08, 2011 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I have a bestec atx30012z and the power turns off after a few seconds of turning it on.
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Nov 20, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Computer has bestec atx-300-12e power supply. it
Actually no, the power does continually comes in but, when stopped, the PS is in a state that could be assimilated to stand-by - only a small side circuit is continually operational.
Jun 23, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Bestec ATX-300-12E Rev. D 300w E-Machine GTW Power Supply Part 100929 (ATX30012E) Power Supply: Do you have to use a emachine power supply...
No it is not neccassary to use a E-machine power supply if your previous one has become faulty. You can use any one as long as it has the required power rating.
May 18, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Can an ATX-300-12E be used in place of an
I think it wont be a problem as long as both pwoer supplies are of same type e.g both supplies are for P4 sytems
Feb 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
EMachine T6420 will only turn on to start the fans and then immediately turns back off - has Bestec ATX-300-12E power supply - do you think that's the problem
These computers have had problems with the mother board. I had one the same problem, and I did research on the INternet. Best advice.... find a replacement board which will fit this box. Then you will have to re-install the operating system with the cdrom. You may be able to repair the system.
More than likely the power supply is not the problem, but the board is suspect more than anything.
Sep 23, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
The PSU bestec atx-250-12e is dead, there is an easy fix for it
You can find the same psu at ebay with free shipping.
http://itemlistings.ebay.com/sdcsrp?fl=360131455504&product=bestec+atx-250-12e&sconstraints=PriceMin.Value%3D23.00%26PriceMax.Value%3D45.59
Aug 20, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
HOW CAN I TURN ON A BESTEC ATX-300-12E PSU OUTSIDE OF THE COMPUT
check on mother bord there is power on key in corner of motherbord.
Some smps has switch in back side of it.
Mar 26, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Upgrade for Bestec ATX-1956D (HP p/n: 0950-4106)
How about the LC Power LC350M Micro ATX - 380 Watt
or the
Logisys 350W Micro ATX
They should fit your form factor and output as much as 350W being relatively cheap, but neither gets 18 amps on 12V rail...
I think no power supply of that size has an output like that...think about a cheap but substancial chassis upgrade if you need that power...Have a look at directron for the PSUs.
Feb 13, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
is the replacement for Bestec 300W
Dec 11, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
209 people viewed this question
Top Bestec Computers & Internet Experts
Lawrence Oravetz
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
