Question about Minka Cirque Brushed Nickel- MinkaAire Indoor Ceiling Fans Fans
Minka cirque ceiling fan burns bulbs when replaced
Exactly the same as following: I have a minka cirque. Every time I put a new bulb in and turn the light on, the bulb blows. I've tried a different switch with no change. I don't see any connecting wiring issues. Fan worked well for 2 years before problem appeared. Electrical feed supplies fan in second room as well and when the fan with the problem is swittched on, the fan in the second room doesn't work. Sounds like a short. Any idea where it may be occuring and how to trouble shoot?
  • 2 more comments
  • cordovacrist Dec 19, 2008
    Any idea where it may be occuring and how to trouble shoot? Should we rewire the whole thing. How can the problem be isolated?
    I turned fan off, even breaker. Then I install bulb, turn power on, turn on light/fan----light blows fan works fine.????!!!
    Very helpful! Thanks
  • Susan Friedricks
    Susan Friedricks Nov 18, 2017
    Did you get an answer on this. I have the same problem.
    Guru:
  • 449 Answers
Is your fan on every time the bulb blows?
Posted on Dec 19, 2008
  • Jerry Parmanand Dec 19, 2008
    There are a few reasons bulbs can blow, the major one being cheaper bulbs. The elements in cheap bulbs are much thinner and any surge of power, however slight, simply breaks them. Always go for expensive light bulbs, its cheaper in the long run.
    A loose connection in the lamp holder can also cause bulbs to blow. This is because the circuit is not completed as tightly as it could be and the electricity may have cause to "arc" or jump across the contact, rather than simply flowing through it. When this happens it produces more heat in the fitting than is expected or catered for by the bulb, and the bulb can blow.
    The same can happen if the spring loaded connection in the bulb holder is slightly loose. This will cause electricity to arc across the contact, cause too much heat and blow the bulb. This can very often be diagnosed by looking at the contact on the bottom of the bulb to see if it is pitted. Arcing electricity effectively melts the metal it is arcing onto ( This is how arc welding works) so if the bulb contact is being subjected to arcing, tiny little indentations occur, called pitting.
    It is sometimes possible, if the live connection in your light switch is a little loos, for this to happen here also. Heat will be generated and it is possible, though very very remote, for the bulb to blow as a result of this.
  • 19,396 Answers
That means that there is a short, check the wiring to the ciling and wiring into the rotating bearings.
  • Ginko
    Ginko Dec 19, 2008
    If the bulb blows while fan is rotating, check the wirings inside the fan , and wirings going to the ceiling, as in this case the short is caused by fan moving and vibrating.
    If the bulb blows immediately when you turn the switch on, check wiring into the switch.
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
My Minka Aire conceptII ceiling fan comes with a 100w bulb. where I can buy a brighter bulb?
most well stocked hardware stores will carry bulbs that are larger then 100watts -- or a specialty lighting shop will also have a higher wattage bulbs.
c...
Feb 24, 2011 | Minka Concept II Flush 44 Ceiling Fan by...
I have lost my instructions and cannot figure out how to replace the burned out light bulb in my Minka Aire F603 ceiling fan unit; I can't figure out how to get to the bulb - can't figure out how to get...
Hi Bill. So far I have not been able to find a manual, but I will keep looking. In the mean time, if you want to give it a try, it appears to me that the circular piece that has the fingers that hold the light globe is probably put in place to hold the globe by a "turning" motion. If you were to reach up and grab this ring and gently turn it counter clock wise I bet it would turn perhaps 1-3 inches and disengage the fan body. Makes sense that the manufacturer would make it easy to change light bulbs and viewing the fan, this would be about the easiest way to do it. I would assume the glass globe is NOT fastened to this ring in any manner, so if you do decide to try this, be ready to have the glass globe release from the holding ring.
I will let you know when/if I find a manual. If you decide to try my solution and are satisfied with it, I would appreciate a Thumbs Up rating from you. BTW, nice fan. Paul
Oct 08, 2010 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: http://minkagroup.net/Admin/UploadFiles/F603-English.pdf It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
Sep 08, 2009 | Minka F603-WH Ceiling Fan
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Mar 30, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Light blows when turned on
I had the same issue. Electrician pointed out my bulb was not 120v like it needs but 12v-hence the problem.....
Feb 03, 2008 | Minka Cirque Brushed Nickel- MinkaAire...
Dryers Logo
289 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Marvin
Marvin
Are you a Minka Dryer Expert? Answer questions, earn points and help others
